burning up points
Old Oct 16, 2002 | 11:52 AM
sullyda1's Avatar
sullyda1
burning up points
Old Oct 21, 2002 | 08:46 PM
wirebrain_8's Avatar
wirebrain_8
burning up points
i have just rebilt my 1972 ford f100 (360) FE with an edelbrok proformer intake bord 30 over heads shaved 30 and crank turnd 10 with mallory dule point distributor holly lasor shot coil and holly 750cfm carb it keeps burning just one set of point at a time but other than that when the motor is reved it pops and back fires and i cant find out what it is if eny one can help it would be greatly aprecheated and sorry for the poor spelling
Old Oct 21, 2002 | 08:56 PM
Mike W's Avatar
Mike W
burning up points
Check the timing and be sure the firing order of the plugs is correct. Make sure the condenser is installed in the distributor. You might try the stock coil for now.
Old Oct 21, 2002 | 09:37 PM
wirebrain_8
burning up points
iv checked the timeing and the condenser is installed there are no plug wires mixed up iv checked that 4 or 5 times
Old Oct 21, 2002 | 10:28 PM
Ratsmoker's Avatar
Ratsmoker
burning up points
Also check and make sure the distributor is advancing. It's not uncommon for the vaccum pot to quit working. Check your timing with a light from idle to 3,000 rpm and see where it ends up. I have never seen a set of points last on a hot motor, I don't care what brand. Pertronix is the way to go my friend.
Old Oct 21, 2002 | 10:41 PM
krazdndenver's Avatar
krazdndenver
burning up points
My money is on a bad ballist resistor. When they go bad you burn pionts and get carbod tracing in the cap. If these are your problems you can check this by checking voltage at coil whiel running. It should be around 7 volts not 12.
Robert
72 Ranger XLT w/ 86 5.0L W/ AOD
krazdndenver(No Email Addresses In Posts!)
www.geocities.com/krazdndenver
Aerostar
Aug 21, 2024 11:23 PM
bradphx
67
Jan 10, 2024 06:12 PM
Mar 9, 2016 12:40 PM
miko6810
Modular V10 (6.8l)
Jun 4, 2014 06:14 AM
Aug 22, 2012 11:39 PM
