Fuel Gauge without function - please help!
Old Apr 7, 2006 | 11:56 AM
South Germany's Avatar
South Germany
Smile Fuel Gauge without function - please help!
Fuel Gauge without function. Anyone have a wiring diagram for a 1986 Ford F250 XLT Pickup? - Please help!!
- Greetings from good old Germany
Old Apr 7, 2006 | 03:20 PM
srercrcr's Avatar
srercrcr
Aveeterzane!
Ford's fuel sending units/grounds is another Ford "Better Idea".
Might as well get used to driving by miles, not the gauge.
That's what I've been doing for the last 100K miles, on both tanks!!
It's just not worth fixing, IMHO.
Old Apr 7, 2006 | 04:40 PM
fellro86's Avatar
fellro86
Try unplugging the sender at the tank, and see what happens, if it reads full, and your guage normally reads empty, the guage is workin as well as they will, it's the sender. It can be as simple as a float that has leaked, filling with fuel, and no longer floating.
Old Apr 7, 2006 | 11:53 PM
Bdox's Avatar
Bdox
That's right. Fuel sending units on old Ford trucks are very unreliable. Mine is bad too but the cost of the replacement is over a hundred dollars and the trouble of changing it has left me uninspired to repair it.
Old Apr 8, 2006 | 01:21 PM
jinserra's Avatar
jinserra
I had the same problem in my old 1983 f150 and When I dropped tha tank and checked the sending unit the float was full of fuel. I went to the dealer and got a new float for about 10 bucks. Problem solved.
Old Apr 8, 2006 | 03:10 PM
reamer's Avatar
reamer
It's easier to remove the bed than drop the tank, That's what I did.
Old Apr 8, 2006 | 08:12 PM
fellro86's Avatar
fellro86
I don't know, it isn't all that bad to pull the tank, all those rusty bed bolts and the fact I don't have ant help, it was easier to pull the tank when it was close to empty.
Old Apr 8, 2006 | 08:48 PM
Franklin2's Avatar
Franklin2
I agree, I would rather drop the tank than pull the bed. Both times I have pulled my bed for other reasons, I have had to grind the heads of the bolts off because they were so rusted.
You can take the sending unit wire off the tank, and with the key in run and someone watching the gauge, ground the sending unit wire. The fuel gauge should go full scale one direction. Then take the wire off ground and let it hang in the air. The gauge should swing full scale in the opposite direction. If this works, then it is the sending unit that is bad.
I would go ahead and take the sending unit out and troubleshoot. Sometimes it is the float, and sometimes there is something wrong with the sending unit inside. Usually the little wiper arm is broke off, or getting ready to break off and is not making contact. I have fixed about 5 sending units on different vehicles by carefully bending the little tabs back on the send unit metal box, and then taking a soldering gun and re-attaching the arm back by soldering it. I have had a 100% success rate so far.
Old Apr 8, 2006 | 08:58 PM
fellro86's Avatar
fellro86
It also depends on which tank is being dealt with, the front sender can be taken out without dropping the tank at all.
