Transmission Questions
Old Apr 7, 2006 | 09:49 AM
jmacr12's Avatar
jmacr12
Ok new here and wondering something, I have a 2001 F250 7.3 and a buddy of mine has a 2003 F350 6.0. I understand I have a 4r100 tranny and he has a 5r100 tranny. Question is whats the diffrence between the 2. Any and all help would be great.
Old Apr 7, 2006 | 10:29 AM
trakman's Avatar
trakman
The 5r100 has the "torque shift" feature that they put behind all 6.0's. I have one of the last 7.3L's built in 03 and it has the 4r100. What the exact difference is, someone else will have to chime in here.
Old Apr 7, 2006 | 11:35 AM
Dsl Lover's Avatar
Dsl Lover
For starters, the number of gears. The torque shift tranny has 5 gears vs 4 gears in the older tranny. The torque shift tranny has a higher torque rating & has a tow/haul mode which, depending on load and road conditions will tow in overdrive & hold the gears longer. The torque shift tranny also locks the TC more often (Even on slowdowns - in tow/haul mode).
The greater number of gears seems to make the truck a bit quicker by keeping more in the power band.
Old Apr 7, 2006 | 11:46 AM
jmacr12's Avatar
jmacr12
Got it, thanks. Knew I could the answer here. Have a good day.
Old Apr 7, 2006 | 01:16 PM
Tenn01PSD350's Avatar
Tenn01PSD350
I gotta ask, will the 6.0 transmission retrofit into the 7.3. Would it be worth it or just have mine properly rebuilt. I know I'm not happy with my OD gear on the interstate with no load, I would prefer lower rpms at 75 mph. Is it any better with the 6.0s?
Old Apr 7, 2006 | 01:29 PM
Casey's Avatar
Casey
The 5R110 will not mate to the 7.3L. An adaptor could be built, but that will cost almost as much as rebuilding a 4R100. Then you'd have to create a computer to run the 5R110. The computer that the trucks use needs to control a 6.0L and 5R110 together to be able to work. Short answer, it can't be done.
Also, the OD ratio is 0.71:1 in both transmissions.
Old Apr 7, 2006 | 02:00 PM
Dsl Lover's Avatar
Dsl Lover
Basically, same answer as Casey. I would doubt the possibility of a retrofit because of the PCM/computer/programming compatability factor. A 6.0L PCM would be different than the 7.3L PCM.
In terms of the RPM factor, I would not assume that it would be lower as the 6.0L has a reasonably higher redline.
Old Apr 7, 2006 | 04:07 PM
cangim's Avatar
cangim
If you really want to lower them in O/D, I would consider a gearvendors unit or re gearing the diffs. I agree though, would be nice to cruise 75 @ 1900 rpm or so. Maybe even lower but I am sure there is a point where it would be too low and negate any mpg advantages.
Old Apr 7, 2006 | 05:05 PM
Clint Knotts's Avatar
Clint Knotts
I here good things from everyone here about Jody's tunes and how he adjust shift points in his tunes and wonder if he can write programs to do a retro fit? I think I like the ideal of haveing another gear.
Old Apr 7, 2006 | 06:58 PM
Tenn01PSD350
I doubt it. I figured the coding would be the problem all along. Didn't figure on the big physical mounting differences. Can't overcome gearing in OD with a chip. If/when mine gets rebuilt, maybe there's a gear in my future.
Old Apr 7, 2006 | 09:40 PM
Brolli's Avatar
Brolli
if you want lower rpm's on the freeway then just add a gear vendors
Old Apr 8, 2006 | 11:21 AM
Clint Knotts
I think I need a differant gear inbetween 2nd and 3rd on hard pulls because I run out of power in 3rd and have to slow down below 45mph to go into 2nd.My gearing to power is off alittle. Maybe a few power mods would make the differance I am looking for.My truck is stock 2000 F-350 DRW 4X4 with 4.10 rearends and 235 tires.
