Remote Start
Old Apr 7, 2006 | 08:43 AM
domf350's Avatar
domf350
Remote Start
Hi All,
I have just installed a DEI561R on my 2005 F350 Powerstroke. I am having a problem with the tach sensor picking up the rpm's. I used the Light Green Blunt cut wire for the PTO RPM monitor. First, does anyone know if this is indeed the correct wire to use and if so, do I need a special part or do I directly tap into this wire?
Also, is there a way to wire it so the lock and unlock work like the factory key fob? Right now all doors unlock / lock when the aftermarket key fob is pressed.
Any advice or suggestions would be greatly appreciated.
