1997 F350 Height
Old Apr 7, 2006 | 06:20 AM
Concept25's Avatar
Concept25
1997 F350 Height
Has anyone ever lifted a 2 wheel drive f350 to give it a better look.Is there a easy way to do it. I have a 2 wheel drive that I would love to give it a few inches , thanks
Old Apr 8, 2006 | 05:10 AM
trike1946's Avatar
trike1946
I'm not an expert. I looked at a few that were lifted already, trying to find one to buy. I didn't want a lift. So in trying to find out how to reverse it I was told it can be lifted with either blocks or springs. Or I guess even a combination of the two. Seems like blocks under the springs would be the easiest. Maybe the gurus in the suspension forum might have an idea. Good luck with it.
Old Apr 8, 2006 | 03:16 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
Never, ever, EVER use blocks under the front springs. The lateral stress placed on the steer axle can be enough to spit the block out.....then you are trying to pilot a deathtrap into the ditch.
Use only taller replacement spring packs, or additional leaves in the stock packs. You can also move the frame away from the spring with a taller shackle.....anything but a block.
Old Apr 8, 2006 | 07:06 PM
trike1946's Avatar
trike1946
cookie88, I didn't realize they were talking about wood blocks. I thought there was some kind of a metal block made for it, that I was told to look for. You are absolutely right. Wood blocks would be dangerous. Good thing you read it. I'll be more careful about that stuff.
Old Apr 8, 2006 | 10:14 PM
soutthpaw's Avatar
soutthpaw
Cookie is correct never to use blocks under the front axle it is actually Illegal, federal DOT I believe. You can add leaves or replace the whole spring pack. the blocks are steel or aluminum depending on the vehicle. depending on how much lift you may need shims to correct the driveline angle to prevent vibration as well as maintain correct caster angles
Cummings Guy
Jul 19, 2017 03:23 PM
3722
Jul 10, 2017 05:00 PM
37Studey
Apr 6, 2017 11:48 PM
Enrique Cantu
Dec 21, 2016 02:07 PM
erich545
Sep 7, 2016 08:24 AM
