Wiring Question???
I tried to search for the answer for this but with no luck. I have a 99 sd v10 (of course ) and i found what looks to me as it is a factory set of wires that are not connected to anything. They are found comming out of the harness on the drivers side right against the firewall? The only reason that i found them are because I am wiring up my brake controller for my camper and was not sure if these "extra" wires were a factory thing. They look like they are shrink wrapped or something to that effect. Any help will be great.
PS..... I have been waiting for the snow to melt so i can put my truck to the test and see how she pulls the 5000# travel trailer....from what i have read there should be no problems but i need to do it to be sure.....
THX
option, or may be in a state that has different emission laws,and does not have a solenoid or switch for that plug. Either way it's cheaper for the manufacter to make the same wiring harness for all of each model. For instance if you do not have fog lamps,the wiring is still there. And a 5000lb
trailer,no problem! I regularly pull up to 10K with no problem!
https://www.ford-trucks.com/forums/s...ustomer+access
find a wireing diagram or go into motorcraft .com and for 10 bucks you can buy 72 hours of time to down load a lot of great information including the wireing diagrams and shop manuals for your truck
i got all i needed in about 5 hours . it all can be printed out also helps greatly haveing true information/ i also for the same 10 got a oasis report and all the tsbs out for my truck . best 10 i have spent on my truck yet.
