Modular V10 (6.8l)
V10 Rough Idle
Old Apr 7, 2006 | 02:37 PM
DUB85's Avatar
DUB85
V10 Rough Idle
Hey Guys, I Have A 2003 F-350 With The V10. It Has About 64,000 Miles On It And My Problem Is That It Seems To Have A Rough Idle When Sitting At Street Lights Or In The Driveway, It Weird, It Idles Ok For A Second The Goes Rough, Then Kinda Smooths Out, Kinda Like My 5.0 Mustang But That Has A Big *** Cam In It And Thats The Way It Runs. I Took It To A Local Ford Dealer Where I Bought It And The Ran All The Checks And Said It Was Ok. I Suggested That It Was The Plugs But They Said No, I Think They Are Jerking My Chain. Does Anyone Have This Problem, Just Wondering Because The Dealer Said To Me " Do You Realize You Own A V10", Like Im A Dumb *** Ya Know? The Truck Shouldnt Really Idle Any Differently Then Any Ohter Truck Ived Owned. I Owned A F-150 Before This And When The Idle Got Like That Id Change The Plugs And It Went Away. Let Me Know What You Think, Thanks Guys.
Old Apr 7, 2006 | 03:09 PM
biz4two's Avatar
biz4two
It could be the plugs, but then it could also be:
MAF dirty
fuel filter needs replacement
IAC
COP (one or more) -- Usually will get a check engine light with a code.
TIP: If you end up replacing the plugs, replace the plug boot at the same time.
biz
_______________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
Old Apr 7, 2006 | 07:16 PM
captchas's Avatar
captchas
Guest
fuel filter, plugs are due even though ford states 100k thats a bs load. give the beast a tune up and clean the t.b out while your at it throw in a big bottle of techron for good messure
ps edit
do as above replace all the coil boots as thats most likely what causeing the miss any way they are cheap and easy while those coil packs are off changing the plugs.and you know the drill on changing them
Old Apr 7, 2006 | 08:08 PM
FortyFords's Avatar
FortyFords
I agree 100% on the above 2 posters.
Chk in here we have a post with pictures on the changing of the plugs.
Use the factory brand plug these tritons don't like aftermarket brands.
Rich
Old Apr 7, 2006 | 09:06 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
The dreaded PCV valve elbow...
Old Apr 7, 2006 | 09:08 PM
FortyFords's Avatar
FortyFords
Art don't we get the chk engine light with that one though ?
for lean condition.o2 's bank 1 bank 2
Rich
Old Apr 7, 2006 | 09:17 PM
krewat's Avatar
krewat
Rich
We? Got a mouse in your pocket?
I don't know, I've heard a few people here and in the 5.4/4.6 forum say that the elbow was bad but no light or codes.
Or, at least, I think I did ...
Old Apr 7, 2006 | 09:20 PM
captchas's Avatar
captchas
Guest
yah art!
a lean missfire that size = mil on most of the time. 64k missfireing ? how were your plugs when you pulled them? had some bad boots?
mine only has 19 and the dealer found 3 of them bad along with the 2 tsb's one of which needs a new t.b. and tps. and reflash due to etc-trim valve of under 3.0 degs.
not every thing is simple but multi problemed at times. at 64k that beast needs a tuneup to start with. plugs, boots. air filter, fuel filter, fuel system cleaner, t.b cleaned, ck all hoses for leaks ect,ect, ect, just to start .
Old Apr 7, 2006 | 09:58 PM
FortyFords's Avatar
FortyFords
Funny Art ! No Mouse ! And I'm not going there either with this joke!
"We" as in haven't we seen this before with the elbow cracked with the MIL light on.
What ever just fix his truck ! and stop fooling around will ya!
Rich
Old Apr 8, 2006 | 08:13 AM
Fredvon4's Avatar
Fredvon4
I have replace several IACs ( well just one or two the others I cleaned) later a mis and bad idle with no codes...found the dreaded elbow and had bought several of them. I replace a couple of the elbows first before the IAC and solved a few trucks rough idle that did not throw a CEL.... but honestly "we" did not seek a code so not sure if a slight leak on the vacuum side actually always throws a code or not
Old Apr 8, 2006 | 08:26 AM
FortyFords's Avatar
FortyFords
One of the main reasons I hate OBDII its not always fail safe or a true indication of where and what,just puts you sort of in the right area.
Codes can be stored ,but if the problem say is chked again within the drive cycle and shows okay no code,until its chked again in the next drive cycle and this senairo goes on untill it fails solid or meets a threshold that is stored in the pcm.
It could be the elbow,simple fix thats for sure
Thanks Fred
Rich
Old Apr 8, 2006 | 01:14 PM
RIDE RED's Avatar
RIDE RED
Possible egr valve stuck open,happened to my bro's 99 f-250.
Old Apr 8, 2006 | 01:55 PM
krewat's Avatar
krewat
Could be, although most (many? some?) V10's came without an EGR...
Old Apr 8, 2006 | 07:54 PM
captchas's Avatar
captchas
Guest
tsb 05-10-14 and 05-22-08 engine miss fire due to coil pack boots
Old Apr 8, 2006 | 11:34 PM
someday's Avatar
someday
i have an 05 e450 that from new or a couple thousand miles has occasionally had a rough idle...sometimes it is as smooth as a babies but and other times if i rest my elbow on the door my hand will shake...it reminds me of my brothers v6 mustang that did the same thing and the engine was replaced...when i get time i am going to buy a real code reader to check for any codes and hopefully it can perform some diagnostic tests...if that doesnt work then i will start by replacing all the spark plugs and boots
dwh039
6.2L V8
Feb 12, 2014 08:23 PM
Wrecker411
Aug 16, 2013 01:36 PM
tc76934
1997 - 2003 F150
27
Mar 13, 2013 08:09 PM
mattk15
2004 - 2008 F150
18
Jul 28, 2011 09:05 PM
drivembig
13
Dec 31, 2009 12:07 PM
