Adding keyless entry to pwr locks
Old Apr 6, 2006 | 09:19 AM
sla3492's Avatar
sla3492
Smile Adding keyless entry to pwr locks
I'm adding Keyless Entry to my power door locks on my 1992 Ford F250 7.3L DSL. The Installation manual states to find out what type of factory power door lock system is in use. Anyone have a clue....I sure don't. It has different instructions depending on the type you have. 1 example is 3 wire grounded switched signal step door locks. and there are several others.
Old Apr 6, 2006 | 09:41 PM
LoosMaster's Avatar
LoosMaster
https://www.ford-trucks.com/forums/f...splay.php?f=62
Try posting in that section of the forum where all the electrical stuff is discussed. Might get more answers or I can get Mustang to move it.
Old Apr 7, 2006 | 12:03 AM
Racerguy's Avatar
Racerguy
The power door lock switches reverse the polarity of the power going to the actuators to change the direction they move. When you press lock it grounds one side of the actuator on the pink/light green wire at the switch and sends 12V to the other side on the pink/yellow wire. When you press unlock it sends 12V to the one side of the actuator on the pink/light green wire and grounds the other one on the pink/yellow wire.
Old Apr 7, 2006 | 07:57 AM
93f1505.0L's Avatar
93f1505.0L
Yup it is reverse polarity. And i put a keyless entry/remote start in my 93 f150 2 weeks ago so if u have anymore ?s just ask.
Old Apr 7, 2006 | 01:01 PM
Kansas-Mike's Avatar
Kansas-Mike
What brand did you put in your truck ? 93f150505.ol
Old Apr 7, 2006 | 04:39 PM
trgrhappy's Avatar
trgrhappy
can I ask how you wired them? relays involved? trying to do my 89. putting a K9 mundial-3 with keyless. I have the alarm in and working, but no door locks hooked up yet. it has factory elec locks. 5 wire reversing polarity.
Thanks
trgrhappy
89 F159 5.0 AOD
Old Apr 8, 2006 | 05:43 PM
93f1505.0L's Avatar
93f1505.0L
Yes relays are needed. I went into the passenger side door and i dont remeber the exact colors of the wires but there is a set coming from the drivers side switch to the passenger switch then from the passenger switch to both lock motors. The wires from the passenger switch to the motors T's off to both motors. You have to put the relay before the T. There should be a diagram in the directions to show you how to hook up the relays. I put mine under the passenger side kick panel or what ever panel is called down to the right but they are not in the door but i guees u could put them in the door if u wanted to. But make sure u have the right kind of relays, i found that part out the hard way. if you need me to go look at the wire colors for ya i will but u should be able to figure it out with a test light.
Heres the brand i put in my truck.
http://www.autotoys.com/x/catalog/CR...S900_p_12.html
Here is a wiring diagram from a 91 ranger but it is that same thing as mine and your truck. This is how i figured out how to do it. I belive the colors are the same too if i rember correctly.
https://www.ford-trucks.com/lc/lc.ph...3d800ba9cd.gif
presidentsdad
40
Sep 29, 2023 03:51 PM
Paul98038
1997 - 2003 F150
Dec 31, 2019 03:57 PM
Brasson1999
Oct 10, 2015 07:43 AM
61 uni
Dec 30, 2008 08:11 AM
Beerstalker
1997 - 2003 F150
22
Sep 27, 2007 06:00 PM
