Thoughts on updating grille and shell
Old Apr 6, 2006 | 07:38 AM
OzFTrucker's Avatar
OzFTrucker
Just after some opinions on changing the grille and grille shell for later model gear. I have a 75 F350 and I was thinking of changing the front to look like my 80 F100(looks like US 79) which would mean new headlights, grille shell, grille etc. Is this common in the US or do you leave your trucks looking like they came from the factory?
Old Apr 6, 2006 | 09:16 AM
73Custom's Avatar
73Custom
It's a matter of taste. Lots of guys swap to the design they prefer, myself included. I put a '79 grill setup in my '73. It was easy, pull the parts off the '79 and install them on the '73. I reused the '73 radiator support, just needed to drill holes for the bottom bolts on headlight bracket. Everything bolted up.
Marty
Old Apr 6, 2006 | 10:00 AM
chet_cowan's Avatar
chet_cowan
Like was said its a matter of taste some people like round headlight and some like square. I like the '77 grille the best as it I think it looks the most hotrod ish.
Old Apr 6, 2006 | 11:46 AM
ivanribic's Avatar
ivanribic
I swapped from the rectangular headlights to the earlier split grill with the round lights. It's easy enough done if you want to.
Old Apr 7, 2006 | 11:34 AM
rchewitt50's Avatar
rchewitt50
So 73Custom it was that easy? Just drill the bottom holes for the headlight bracket? I acutally wanted to start a forum to answer this very question and sure enough there was one going. Is the hole location for my 77 F250 headlight bracket any different then the 73?
By the way, I love this website. It keeps me from working too much.
Old Apr 7, 2006 | 11:52 PM
busted knuckle's Avatar
busted knuckle
my question- not to hijack but are there any differences inbetween the 78 round and the rectangular lights? i had an opportunity to get the lights and pans from a freind so i could just change them out at will. in your opinons are there any differnces in the actuall lighting? thanks
Old Apr 8, 2006 | 06:23 AM
brown79's Avatar
brown79
i did that swap(79 rectangular to 78 round) i changed the brackets (no drilling needed) and got the round bezels thats it no other changes
Old Apr 10, 2006 | 11:14 AM
eedvark's Avatar
eedvark
OzFTrucker I think alot of trucks here end up with '78 or '79 noses because the '78 and '79s had better galvenizing (both sides) than the previous years.This means alot of rust area truck noses from '78 and later survived.It was also an easy way to look like you had a new truck in the late 70s.Anyone have any thoughts about doing it to lower your headlights on a lifted truck?I know some states measure lift by the height of the headlights.
Old Apr 10, 2006 | 02:01 PM
73Custom's Avatar
73Custom
[QUOTE=rchewitt50]So 73Custom it was that easy? Just drill the bottom holes for the headlight bracket?QUOTE]
It's very easy, just a matter of swapping parts. Get the parts off the donor pickup. Don't forget to get the top corner brackets, they have ears that hold the corners of the grill shell (you will know what I mean when you see it). These brackets are different for '78-'79, and this is where the top of the headlight buckets bolt. So you get the correct positioning for the headlights, just need to drill two holes for the bottom of the headlight bracket. Then just bolt on the other parts. You will need to splice the '78-'79 blinker light socket to your old wiring. This will work for any '73-'77 pickup. It took me a couple hours (front bumper needs to come off), and I chose to use the '79 bumper, I like the shape better than the older one...
Marty
Old Apr 10, 2006 | 07:27 PM
eedvark's Avatar
eedvark
The later bumper needs to be used anyway. The shape of the frame ends fit one bumper or the other.
Old Apr 10, 2006 | 08:57 PM
unrulee's Avatar
unrulee
I dunno I've got a bumper off of a 72 F100 on my 79 3/4 ton and it fit without any problems, and I took the 79 bumper off of my truck and put it on my dad's 77 150 and didn't have any problems there either.
Old Apr 10, 2006 | 09:01 PM
eedvark's Avatar
eedvark
The curve of the bumper and frame are different.I dont have a year to year facts on it but most '79 bumpers curve back toward the truck while most earlier bumpers do not have this covex curve.
Old Apr 11, 2006 | 09:07 PM
rchewitt50's Avatar
rchewitt50
That is perfect! Thanks!
Old Apr 12, 2006 | 10:30 AM
73Custom's Avatar
73Custom
'78-79 have the more squared bumper, while '73-77 have the more rounded one. My '73 and '79 2wds had the same shape to the front of the frame, the '79 bumper fits fine on my '73. I went with the '79 bumper just because I prefer the look.
Marty
Old Apr 12, 2006 | 02:13 PM
78f-150Supercab's Avatar
78f-150Supercab
I'm considering swapping out my 78 grill to a 77 grill. I used to hate the look of the 73-77 grills and loved my 78, but lately, the 73-77 grills have grown on me. Now I really like the look of the 76-77 more than the 78 but still don't like the 73-75 grills as much.
The 76-77 grills look really good on lifted trucks, which mine will eventually be, but I think the 78-79 grill still looks better on most stock 2wd trucks (which mine currently is) so I'm not really sure what to do right now. My 78 grill shell is damaged and I need to get a new one, and I have a chance at getting a 77 grill in near-perfect condition.
I'm also getting a 77 bumper and guards, so that would match the 77 grill better... ugg... decisions decisions.
