Rear Wheel Bearings
Old Oct 21, 2002 | 10:46 PM
user 5363849's Avatar
user 5363849
Post Rear Wheel Bearings
I need rear wheel bearings for my 71 F-100. My VIN is F10YRL27813. I've included on line listings from Kragen (Checker, Shucks) and Autozone.
Autozone lists...
TIMKEN 514003
TIMKEN A-7 - SPICER 44-3 AXLE
TIMKEN INNER 514003P CAN ALSO BE USED
Kragen lists...
CHICAGO RAWHIDE BR7 - Spicer 44 & 60 Axles To Ser # A24999
CHICAGO RAWHIDE CBR7
CHICAGO RAWHIDE R1580-TV - 3600# & 3750# Ford Axles
BCA BEARINGS A-7 - Spicer 44-3; To Serial # A25
BCA BEARINGS 514003 - 3300 Lb. Ford Axle
BCA BEARINGS RUB-1580-EBFR - 3600 & 3750 lb. Ford Axles;
MOTOR CITY S-A-7 - Spicer 44-3; To Serial # A25
MOTOR CITY S-514003 - 3300 Lbs. Ford Axle
How would I know if I have a Spicer or a 3300, 3600, or 3700? I would presume that I have the 3300 simply because this is a base line truck. Any suggestions?
Thanks
Old Oct 21, 2002 | 10:52 PM
krazdndenver's Avatar
krazdndenver
Rear Wheel Bearings
I perfer Timkin bearings over all. I would take in an old one to size up with the new one.
Robert
Old Oct 24, 2002 | 09:16 PM
rebocardo's Avatar
rebocardo
Rear Wheel Bearings
I just replaced axle bearings in my 1971 F-100 with a Ford 9 inch with 28 spline axles. Autozone #
#012316 514003 (Timken?) rear wheel bearing with retainer. I believe some of the listings you posted are with/without bearing retainer and with/without axle seal. Mine was just bearing and retainer.
Old Oct 28, 2002 | 10:31 PM
sullyda1's Avatar
sullyda1
Rear Wheel Bearings
[updated:LAST EDITED ON 28-Oct-02 AT 11:32 PM (EST)]Spicer rear ends look different than a 9" type rear end. On a Spicer, the axle tubes press into the rear center housing, thus 3 separate pieces. The 9" housing is one piece from axle flange to axle flange.
Old Oct 28, 2002 | 10:34 PM
Mike W's Avatar
Mike W
Rear Wheel Bearings
Purple55
33
Feb 15, 2025 07:47 AM
creator
Apr 24, 2023 04:01 PM
AmeriKen
Apr 9, 2023 08:26 PM
fordpride
Sep 13, 2016 10:57 PM
pitpawten
Nov 23, 2015 03:04 PM
