looking to put an exhaust tip on my truck and need to know what diameter the pipe is on an 01 V10. Also has anyone put one on theirs. The reason i am not doing the full exhaust yet is that i haven't found one that i really like sound wise, so in the mean time i am going for looks. Thanks
its 3 inch and ford has a part number for a factory tip.
Pipe asy kit - chrome tip with instruction sheet (accessory) - 2002/
<br>
2C3Z 5K238-AA
<br>
I looked it up for a 2001 and here is what is listed.
<br>
Ed
I had a same size as stock diameter chrome tip welded on to the new gal by the guy that did my spray in liner... cost an extra $20 for the tip and he cut back the squared off tail pipe and tack welded the tip on for free.....
I kinda like where he had cut the stock pipe back to... about the chRome tiP??? Just another damned piece of crap to get mud and asphalt baked onto... I gave up cleaning and polishing the damned thing a year ago... looks just like the factory should have set up the final 8 inches...simple turn down oval cut outlet.
I took 800 grit wet & dry to my tailpipe, followed that with 1500 grit and I have to tell you that sucker shines real well. I use SS cleanser once a week and it stays mighty nice looking.
