Front End To Low
Old Apr 4, 2006 | 02:04 PM
VQ2Fast4U's Avatar
VQ2Fast4U
Front End To Low
The weight of the diesel motor is taking a toll on front end, no problems just sits very low. I came across these;
http://www.customsuspension.com/stor....php/cPath/492
http://www.customsuspension.com/stor....php/cPath/543
What do you guys think? And im posting in the diesel forum because im sure having a sagging front end is more of a problem for the diesels. Thanks
Old Apr 4, 2006 | 02:12 PM
zx250's Avatar
zx250
Of the next Riffraff East
Here's what I used.
http://www.jackit.com/ford/ford_leveling_kits.htm
Stiffer ride, but it need to be. Now it is not so mushy and looks good. I used the 2.5" for my 99.5
Old Apr 4, 2006 | 02:22 PM
arrowpilot's Avatar
arrowpilot
You will get a better ride out of a reverse shackle system.
Old Apr 4, 2006 | 02:32 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
reverse shackle? do you mean on that has the shackle at the front and the pivot at the front? i dont see how, as the axle is pushed backwards as it hits obstacles in forward driving, but if it were backwards, the shackle wouldn't be there to absorb some shock.
for a leveling kit, i would go with a complete new spring pack and new shocks. that is what i did, and i love it. it gives a smoother and more progressive ride. it's more firm, but not buckboard stiff. doesn't ride like a car anymore. still pushes around tight (how tight can you turn with a 172" WB ) turns some, but not as bad as stock. some people have gone the cheaper route, and added an "add-a-leaf, which is just another leaf that you slide in under the stock springs to help give them support. along with the support comes more load bearing capacity, which means a stiffer ride.
i got my kit off ebay, at $320 its a great deal with new packs.
Old Apr 4, 2006 | 02:37 PM
arrowpilot's Avatar
arrowpilot
Well....let me rephrase.
I have read that you can get a better ride from a reverse shackle.
My b-n-l is about to have it done to his 6.0 F350.
Guess I better hide and watch before I type.
Old Apr 4, 2006 | 04:30 PM
CAT_man_963's Avatar
CAT_man_963
I think someone is confused - you WANT the shackles where they are now. They "reversal" kits and advertised "better ride" are for the OBS trucks that had the shackles right under the front bumper, instead of at the back of the spring.
Old Apr 4, 2006 | 04:58 PM
dsldandually's Avatar
dsldandually
how is he gonna do a reverse shakle kit on a truck with coil springs???????????
Old Apr 4, 2006 | 05:38 PM
clux's Avatar
clux
I used the 16' gooseneck trailer kit with 4 or 5 horse in it. Levels it right out.
Rides a lot smoother too.
Old Apr 4, 2006 | 05:49 PM
PowerstrokeJunkie
um? its a 4wd right? that uses springs.
