tranny help needed
Old Apr 4, 2006 | 11:23 AM
prettygt2's Avatar
prettygt2
tranny help needed
I bought a 96 F350 PSD in December with 220,000 miles and starting in January we started getting a weird noise when driving at highway speeds. It happened very infrequently but we had a feeling that it was the torque converter. No one was able to diagnose it because it rarely happened. Well, Saturday night a new noise started in the tranny area and then we came to a stop sign and it decided it didn't want to move anymore. We checked the fluid and it was not on the dipstick (we had just checked it a few weeks before and it was fine). So we put fluid in it and it moves now but we hear grinding. So anyway, if I hear grinding, the tranny is definetely bad, right? Can a bad torque converter take out the tranny too? Should I just buy a new tranny or have the local tranny shop rebuild it? Does anyone have any brand preferences? What about converters? We have had a lot of crap break recently and so the money isn't real abundant. Any help/ advice would be greatly appreciated.
Old Apr 4, 2006 | 11:40 AM
Ron McCafferty's Avatar
Ron McCafferty
usually E4ODs when they get to grinding are not rebuildable. factory E4ODs are junk. if you plan to do alot of towing you may want to check out a Tecumseh rebuilt trans. i know you said money is short but if you can afford to save for it they are worth the money. if not you can go online and find a used trans. check out LKQ you can have it delivered to a business and there is no core. if you get a used one you may want to get a new convertor and make sure the pan is opened up at a minimum.
Old Apr 4, 2006 | 11:55 AM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
Talking
"factory E4ODs are junk" really! come on Ron. Now I have to get a different job.
Motorcraft<SUP>®</SUP> and Genuine Parts Remanufactured Transmissions are now backed by a 36-month/36,000-mile warranty
Motorcraft<SUP>®</SUP> and Ford Motor Company Genuine Parts Remanufactured Transmissions are now covered by a 36-month/36,000-mile limited warranty. The new 36/36 service part warranty completes the Total Value Package offering for our products, which strengthens our position in both the retail and wholesale powertrain business.
The Motorcraft<SUP>®</SUP> Transmission Total Value Package
  • Warranty
    • Nationwide warranty for parts and labor backed by Ford Motor Company
    • Competitive 36-month/36,000 mile limited warranty coverage
  • Availability
    • Full product offering with coverage back to 1987 model year
    • Over 50 powertrain warehouses nationwide
  • Quality
    • Ford Motor Company's remanufacturing process incorporates the latest product modifications and technology
    • All the right OE parts are included to ensure quality performance; the right assembly for the vehicle, not just any assembly
    • Q1 and QS 9000 certified suppliers
    • Supported by Ford Original Equipment engineering
    • Standardized build levels with the most stringent specifications
    • Only highest quality core used - all are thoroughly inspected to meet Ford Motor Company specifications
    • Critical replacement parts approved by Ford Motor Company
    • Process Validation Testing to verify component parts and assembly process
    • Every transmission from Ford and Motorcraft<SUP>®</SUP> is dynamometer tested for:
      • Hydraulic pressure
      • Proper shift points
      • Converter stall speed
      • Converter lock-up points
      • Oil flow and pressure
    • New Parts include:
      • Gaskets
      • Seals
      • Solenoids
  • Value for your money
    • Competitive Pricing for OE quality
    • OE quality means less repeat repair and higher customer satisfaction
    • Assemblies are "family-priced" for easy quoting
Old Apr 5, 2006 | 07:42 AM
Ron McCafferty
yeah, i'd say they are. got 285,000 on my f350 ps and put 2 in it before 150,000. and i am not hard on my truck by any means. got one from tecumseh and haven't had a problem since. anyone who buys an f250 or 350 is going to use it for work and they should be built to last.
Old Apr 6, 2006 | 10:31 AM
prettygt2's Avatar
prettygt2
Thanks for the help, where can I get Tecumseh? I guess I'll just do a search. It just frustrates me that the truck lasted 230,000 for it's precious owner and then takes a dump on me in less than 3 months. I love the truck though so I guess I'll drop a couple grand into it and keep truckin'.
Old Apr 6, 2006 | 12:16 PM
Ron McCafferty
Wink
your welcome. you can get one from a tecumseh dealer by searching online. i've got one in my truck. after two factory rebuilds in the 1st 150k i had to do something different. a few tips for driving w/ an e4od. if you are towing alot and by alot i mean on a wekkly basis, you should change your trans fluid btwn 15-30k miles faithfully. and don't drive around town in OD. the vibration in low end kills these trannys. a few things i did with mine was i added a trans temp gage if the trans fluid gets to above 240 degrees it is usually no good anymore. also make sure that the heat shields are in place on the turbo down pipe the trans cooler lines run right next to it and you don't need extra heat. you may want to use synthetic or mercon V trans fluid (better grade). well, good luck with your truck. hope everything goes well. and don't worry you made a good choice. i would buy anything else but a ford. if you take care of it it should last you at least another 2-3 hundred thousand.
Old Apr 7, 2006 | 09:13 AM
DaBigTow's Avatar
DaBigTow
Mercon 5 is a big NO-NO in the E4OD; too slippery. Stick to Mercon-compatible oil.
nick_ct_203
Jun 30, 2017 01:54 PM
Pibryan
Jan 7, 2017 03:22 PM
brichert
General Diesel Discussion
Jun 29, 2016 03:11 AM
Txplanebuilder
Feb 4, 2016 09:00 PM
BlueOvalRage
Dec 3, 2010 08:15 PM
