HPOP -Ring replacement
Old Apr 3, 2006 | 02:59 PM
Spirit615's Avatar
Spirit615
Does anyone happen to have a diagram that come post up showing the HPOP, or tell me where to get started at. I need to change out the o-rings on it. THanks much.
Old Apr 3, 2006 | 04:25 PM
wlihntr's Avatar
wlihntr
when you buy the kit it has a picture of where every thing goes. getting the oil lines of is a little tricky with out "speacial tool" that is needed. i just read somewhere you can get a tool from NAPA that will work but it is like an AC or clutch fitting tool....let me see if i can find it.
NAPA carries a similar tool to what is called for in the service manual. The part number I believe is 3418. It is used for hydraulic lines on Ford clutches IIRC, but will work for hpop lines also.
Old Apr 3, 2006 | 05:02 PM
Spirit615's Avatar
Spirit615
Awsome, thanks for the info! Hopefully this fixes my leak and its not a internal pump leak.
