Transmission fluid question....
Old Apr 2, 2006 | 09:36 PM
cajunstunner's Avatar
cajunstunner
What type tranny fluid does a 1980 and 1981 Ford F-150 use? It's automatic, of course.
Old Apr 3, 2006 | 02:07 AM
fellro86's Avatar
fellro86
what tranny do you have? Most likely it will use Dexron, but not always.
Old Apr 3, 2006 | 02:20 AM
big hoss 29's Avatar
big hoss 29
I used to use the Mercon/Dexron III stuff when I had an auto trans, worked for me.
Old Apr 3, 2006 | 02:25 AM
fellro86's Avatar
fellro86
The only reason I state what I did is there are some that required type F, and use of Dexron would cash it out as the makeup of the fluid is different, but by that year, I believe those tranny's were phased out, the old FMX had asbestos clutches, and use of Dexron would cause slippage.C-4's and 6's had paper clutches and were spec'd for dexron.
