Speedometer calibration
Old Apr 2, 2006 | 09:32 PM
MikeRizz's Avatar
MikeRizz
I just put on new 285/75/16's on my X. Do I need to have the speedo calibrated ? If so, is this a dealer only thing ?
Old Apr 2, 2006 | 10:42 PM
RACERX7775's Avatar
RACERX7775
its not going to be off more than 2mph anyway. i wouldn't waste your money.
Old Apr 3, 2006 | 09:48 AM
Fords4Me's Avatar
Fords4Me
When I switched to the 285s it made mine more accurate. But it now shows 63 when I'm doing 65.
Do they ever put up those "you are speeding" trailers that show your speed near you? They do by me all the time
Old Apr 3, 2006 | 01:53 PM
igotoneforya's Avatar
igotoneforya
Racer is right, it is not off enough to worry about. The dealer can do it for 40-75 depending on the dealer. Takes only a few minutes. An aftermarket programmer/tuner will also do it but they cost more (300) while providing better air/fuel mixture ratios to improve power and possibly economy. I have 35" tires and never redid the speedo, I just know how much it is off...
Old Apr 3, 2006 | 09:02 PM
NewXer's Avatar
NewXer
Originally Posted by Fords4Me
...it now shows 63 when I'm doing 65.
Ford4Me, any idea on what the correct reading is at 75 on the speedo?
Thanks,
Larry
Old Apr 4, 2006 | 02:13 AM
RACERX7775's Avatar
RACERX7775
yeah, if it is showing 75 then you are doing about 77 mph.. its still 2 mph difference.
Old Apr 4, 2006 | 04:54 AM
Fords4Me's Avatar
Fords4Me
It's off by a certain percentage. Once you find out YOUR 2 numbers you can figure it out with a calculator.
And yes it's between 72 and 73.
Old Apr 4, 2006 | 09:31 PM
NewXer's Avatar
NewXer
I figured it wouldn't vary much... Thanks a bunch.
Old Apr 5, 2006 | 05:12 AM
Fords4Me's Avatar
Fords4Me
Definitely a percentage. Mine is 3%. My F150 was 10%, which really sucked.
Old Apr 5, 2006 | 02:57 PM
RACERX7775's Avatar
RACERX7775
any change can be converted to a percentage.
Old Apr 6, 2006 | 05:44 AM
Fords4Me's Avatar
Fords4Me
And once you do that you can figure out when you will be setting off the nice officer's radar unit.
Old Jul 12, 2006 | 05:39 PM
Alaskan350's Avatar
Alaskan350
Here is a link for some calculators that I use all the time. Last one on the bottom is what you are looking for.
http://www.tyres1.com/tech_calcs.html
Zach
Bryzzle
1997 - 2003 F150
Jan 12, 2018 06:10 AM
ford351c594
Apr 23, 2016 09:23 AM
DanielT28
Aug 8, 2015 06:44 AM
Softtopper
Feb 28, 2008 06:45 PM
78fordman
General Automotive Discussion
Aug 19, 2007 03:03 PM
