I know this is a F Series forum, but figured knowledge is somewhat universal.
I have a 95 E150 Van with the 5.8, the axel code shows as 19. A Ford 3.55 Non-Traction lock axle. I am going to start towing a trailer with this van and want to swap in a limited slip axle with a deeper gear to help the tranny a bit. I am thinking 3.73's should do the trick.
For the actual question, are axles from the F series a swapable consideration ?
