Sponsored by: Real Truck
Lockout Hubs Choice ?
Old Apr 3, 2006 | 02:13 PM
BFR250SD's Avatar
BFR250SD
Yeah, one reason that caught my attention is I remember looking at that when I'd buy props for the boat. Some companies would give you a break away aluminum hub for the center of the prop, where as other would just slip right on the prop shaft.
MUCHO DENEIRO to replace lower unit parts. Nice and cheap to replace a stripped prop hub. Don't ask how I know this!!!! Ahem.......$3500 worth of damage from a concrete piling. Ooooops!
Old Apr 3, 2006 | 02:25 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Oh, that I DO understand! Here on Long Island, you don't use a stainless prop.
Otherwise, you'll be rebuilding the lower-unit almost every time you go out.
Old Apr 3, 2006 | 02:31 PM
BFR250SD's Avatar
BFR250SD
Yup, I'm originally (and for most of my life) from Upstate NY. EVERYTHING in the Adirondacks is a rocky bottom. If you want a stainless prop, you better run an aluminum hub.
Sorry, didn't mean to get so far off topic.
Old Apr 3, 2006 | 03:06 PM
krewat's Avatar
krewat
Maybe NOT so off-topic...
If it's aluminum, they'll "break away" before breaking some other more expensive part.
I was just googling this topic, and found someone with "hub fuses" - special replacements for the inside of the Warns that break before you break an axle or u-joint.
Hmm...
Old Apr 4, 2006 | 04:37 AM
BFR250SD's Avatar
BFR250SD
Really, that's a pretty smart idea.
Think about how much of a pain in the butt it is to replace the stub shaft. Heck, you might as well replace the ball joints and unit bearings while you're at it, because all that stuff has to come off to replace the stub shaft.
Whereas if the hub grenades, you just pop the snap ring, pull the hub, and drop in a new one...............5 minutes...........Done.
Old Apr 4, 2006 | 09:29 PM
grif95's Avatar
grif95
This is where I got mine from.....
http://www.tellico4x4.com/catalog/pr...ducts_id/12833
Mile Marker Hubs for $121.95 + $20.95 for Shipping = $142.90. This was the best price that I could find.
droldsmorland
Jul 12, 2016 08:40 AM
rossgn
Dec 9, 2013 09:18 AM
xmontex4
Oct 13, 2012 04:33 PM
SMB
Feb 21, 2003 09:29 AM
