96 Explorer key fob re-program
Old Apr 2, 2006 | 05:45 PM
pbetzer's Avatar
pbetzer
Had to replace my alternator, at that time I lost the use of my remote...
nothing in my owners manual about reprograming, door key pad still works...
please give information as to where to find info on getting my key fob remote to work...
Thanks in advance
Old Apr 2, 2006 | 06:30 PM
JerrySimm's Avatar
JerrySimm
Itmay be the same as my 2003.
Here's what my 2003 owners manual says;
How to reprogram your remote entry transmitters
You must have all remote entry transmitters (maximum of four)
available before beginning this procedure.
1. Ensure the vehicle is electronically unlocked.
2. Put the key in the ignition.
3. Turn the key from the 1 (LOCK) position to 3 (ON).
4. Cycle eight times rapidly (within 10 seconds) between the 1 (LOCK)
position and 3 (ON). Note: The eighth turn must end in the 3 (ON)
position.
5. The doors will lock, then unlock, to confirm that the programming
mode has been activated.
6. Within 20 seconds press any button on the remote entry transmitter.
Note: If more than 20 seconds have passed you will need to start the
procedure over again.
7. The doors will lock, then unlock, to confirm that this remote entry
transmitter has been programmed.
8. Repeat Step 6 to program each additional remote entry transmitter.
9. Turn the ignition to the 1 (LOCK) position after you have finished
programming all of the remote entry transmitters.
10. The doors will lock, then unlock, to confirm that the programming
mode has been exited.
You should probably double check your manual to make sure the procedure is not in there. If you dont have one, you can download one from here; http://www.genuineflmservice.com/default.asp?page=E4
Good Luck...........
Old Apr 2, 2006 | 11:22 PM
pbetzer's Avatar
pbetzer
Thank you that worked however it only took 3 turns of the key... and no this information is not in my owners manual or in the $45.00 1996 Ford Tech manual.
Thanks again
Old Apr 2, 2006 | 11:46 PM
pbetzer's Avatar
pbetzer
I just downloaded the new manual that JerrySimm referenced... It has a lot more info than my book that cam with this explorer. (Full towing weights are in new version... )mine is dated June 1995
Thanks for your help
Old Apr 3, 2006 | 08:22 AM
JerrySimm's Avatar
JerrySimm
Glad it worked. I didn't know how different it might be from my '03. I read a thread here regarding the '94's that two terminals had to be jumped in a box inside a rear quarter panel, but that was supposed to only be for '94's.
Old Apr 10, 2006 | 11:47 AM
tapper95's Avatar
tapper95
So the book says that I need 2 keys and I only got one when I bought the truck from a Ford Dealer 5 years ago...
What's the going price to have a second key made and programmed? Am I better off buying a blank SucuriLock Key on eBay and bringing it to the dealership?
Anyone have to do this?
Old Apr 10, 2006 | 08:49 PM
JerrySimm's Avatar
JerrySimm
You'll need to call your dealer to see what they charge. Probably over $100, although some charge less. Also, some advanced locksmiths can do it and will do it cheaper, check around. Also, you don't mention what year, but you probably have a PATS key system.
Old Apr 11, 2006 | 12:33 AM
tapper95's Avatar
tapper95
It's a 99, and I think you're right about it peing PATS and not SecuriLock... I have use a locksmith near me for some business related things, and he seemed to be top grade since he did some work for me that another locksmith had turned down...
I'm taking our 96 Explorer in for the mystery brake light problem in the morning, so I'll try to remember to get a quote...
Old Apr 11, 2006 | 05:35 PM
JerrySimm's Avatar
JerrySimm
Regarding the Locksmith, it will be determined by wheather or not he has the box to talk with your computer.
Old Apr 11, 2006 | 06:34 PM
tapper95's Avatar
tapper95
Ford dealer wants $23 per key and a one time programming fee of $76... It's a friggin' key!!! I'm going to shop around... luckily my wife's is a year or two before PATS... It started in 97 or 98 they told me
Old Apr 11, 2006 | 07:26 PM
JerrySimm's Avatar
JerrySimm
I spent around $15 per key for some spares for my '03 off of EBay. Then I had to get them cut locally. But I had 2 originals, so I could program my own. All in all, that dealer cost isn't as bad as a number that I've seen written about on this site, but you still may be able to do better.
Old Apr 11, 2006 | 08:20 PM
tapper95's Avatar
tapper95
I was thinking about buying a couple off eBay, but I only have one key so I have to bite the bullet on at least one key... I'm just trying to find the cheapest bullet to bite...
Twinsdad98
2004 - 2008 F150
Apr 9, 2017 01:07 PM
7622RM
1983 - 2012 Ranger & B-Series
Aug 17, 2016 12:36 AM
ride_red
2004 - 2008 F150
Jun 15, 2015 06:22 PM
selmerSA80
Jul 17, 2014 08:41 PM
mkac100
Oct 9, 2009 07:35 PM
