Wheel Lug Nut Size
Old Apr 2, 2006 | 02:06 PM
rplatt7's Avatar
rplatt7
Wheel Lug Nut Size
Ok, so I bought a front bearing hub for my 2001 F250 SD 7.3 4x4 from a person on ebay. It was brand new in the ford box at a terrific price that I could not pass up. He told me that the lug thread may be different. So that is the problem I need new lug nuts and don't know what size to get. The thread looks finer then the original. Everything on the hub is the same but that. The part # on the new hub is 3C3Z-1104-BA.
Also I need a new fiber washer that goes in between two metal washers on the outside of the bearing hub. Is this a factory only part and what is it called.
Thanks
Old Apr 2, 2006 | 02:24 PM
clintbonnie's Avatar
clintbonnie
On the thread size, just measure the lug diameter, use a wrench if you don't have some calipers. It is probably 9/16" .. Carefully count the threads in one inch.. I would guess it is 9/16 X 18.. if you say it is a finer thread.. (12 would be course)
Old Apr 2, 2006 | 02:40 PM
CAT_man_963's Avatar
CAT_man_963
They are metric - they changed from 14 - 1.5 thread pitch, to 14 - 2.0 thread (some time in late 2002 I think) - if your new one looks finer I'd say that's what it is.
Old Apr 2, 2006 | 02:41 PM
SpringerPop's Avatar
SpringerPop
Metric.
Pop
BlueOvalBud
41
Mar 4, 2024 08:56 PM
sammie0126
Dec 21, 2016 12:24 PM
AMG-SM
Dec 25, 2012 01:34 PM
shore
Nov 17, 2012 10:27 PM
cws10190
18
Sep 25, 2012 08:55 PM
