Offroad & 4x4
Clutch problem in water?
Old Apr 2, 2006 | 01:58 PM
wvmudder's Avatar
wvmudder
Does anyone know what a person can do to keep water out of a bellhousing when mudding? Well, anything except staying out of the mud and water?
This is ussually only a problem during the spring, all my friends tell me to swap to an automatic but I like my 4-spd.
Is my only option to seal it the best I can with silicone and run a vent from the top of the bellhousing up the fire wall or into the cab? Thanks, Dave
Old Apr 2, 2006 | 02:51 PM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
dont push the clutch in when its in water
Old Apr 2, 2006 | 04:25 PM
chrono4's Avatar
chrono4
if it were only that easy. but yeah, when gettin into the hole, pick a good gear and keep it there. when you do have to shift, which you will eventually, only push the clutch as far as you need to, and dont dump it, let it back out slow, push some of the water out. you also could try the sealing it up
Old Apr 2, 2006 | 05:03 PM
fordtruggy's Avatar
fordtruggy
Speed shift it so you dont use the clutch.I havent had a problem yet but would seal it up if i did.
Old Apr 2, 2006 | 05:05 PM
chrono4's Avatar
chrono4
you have any idea how bad that is on a tranny, specially when your running bigger tires, and what not?
Old Apr 2, 2006 | 06:00 PM
Flareside94's Avatar
Flareside94
It's not hard on them at all if you do it right. I can almost do it with my M5OD if I'm feeling retarded...but my M5OD is a POS anyways. Even new those don't like to be treated that way.
Old Apr 2, 2006 | 06:45 PM
proeliator's Avatar
proeliator
And don't forget to doubleclutch while your living your life one quarter mile at a time
Old Apr 2, 2006 | 09:30 PM
KubotaOrange76
how the hell would you speed shift a 435 going from 1-2nd....they hardly like to make that shift with fresh syncros
Old Apr 3, 2006 | 12:39 PM
wvmudder's Avatar
wvmudder
LOL, I live my life one mud hole at a time.......I wonder if he felt like a d**che bag because of that line
I have thought about using some sort of gasket material on all the metal to metal areas and running a vent hose up the firewall but if I did get a little water in the bellhousing or clutch it wouldnt drain or it would take forever to drain. What do you guys think? Dave
Old Apr 3, 2006 | 01:07 PM
KubotaOrange76
i dont htink theres a way to seal the clutch from getting water. if you try, and when water gets in....then its gonna take a long time for it to come out
Old Apr 3, 2006 | 04:42 PM
mustange70's Avatar
mustange70
Here's what i do, for the bottom of the bellhousing where that tin pan is i run a bead of silicon (the blue stuff) to seal this off, and then i run the silicon up as far as i can between the block and bellhousing and tin cover. I also run a bead along the edge of the starter and the bellhousing, then i do the same thing for the rubber clutch boot, but i leave the center where the clutch fork goes through the boot, and this acts as my vent, i also seal the starter up the best i can, but it still needs to be a lot better for the starter anyway.
TO drain the bellhouisng i'd cut into that tin cover and make an inspection cover such as on automatic tranny's to undue the convertor bolts, then just be sure to seal it up good.
So far i've only got enough crap in the bellhousing to fubar a few starters (so far my only reacurrent carnage), but thats what i've done.
Old Apr 4, 2006 | 07:33 AM
wvmudder's Avatar
wvmudder
That sounds like a good Idea since I have a couple of those automatic tin plates with the inspection cove in the bottom. Thanks for the helpful tip, Dave
Old Apr 4, 2006 | 12:17 PM
Thomsen's Avatar
Thomsen
I tried sealing off mine but it will be extremely hard to get it COMPLETELY sealed. I got stuck in some deep water once and muddy water found it's way in, it had no way to drain out so it dried up in my pressure plate and caused a big headach. I unsealed the bottom so that it could drain out and have left it at that.
Old Apr 4, 2006 | 01:40 PM
KubotaOrange76
thats what i have found....you may be able to get it sealed off, but it wont last long and water will get in and take a LONG time to get out
Donna Judy-Creasman
1978 - 1996 Big Bronco
Mar 24, 2013 05:12 AM
Loud4.9
Bronco II
Jan 12, 2011 07:36 AM
masseysbronco
May 10, 2010 09:34 PM
LilDuke
Jul 13, 2004 09:01 AM
Cop Bait
1997 - 2003 F150
Mar 13, 2002 10:14 PM
