351C fitment question
Old Nov 12, 2002 | 12:48 PM
pward76's Avatar
pward76
Will a 351C fit in a 70-72 F100 that already has mounts for a V8?
The next question would be about fitting a manual tranny to it... which one? will it bolt up? am I nuts?
Thanks
Old Nov 12, 2002 | 05:44 PM
Jimbare's Avatar
Jimbare
all alone in the world
1st, depends on what v8 mounts it has in it.
2nd, you can bolt about any standard tranny you want in it with the right bellhousing.
Old Nov 12, 2002 | 08:31 PM
pward76's Avatar
pward76
Thanks Jim,
I have located a 351C that I want to put into a truck with as little fuss as possible. I haven't found a truck for it yet - I'm looking for a 70 - 72 since I prefer this body style to the 73 and 74, and these were the years the 351C was available. So, as long as I'm looking for a truck, it makes sense to me to get one that will have the correct mounts.
Can you tell me which engine mounts would match the 351C? And if so, where in the heck do you find this info? You guys are amazing.
Old Nov 12, 2002 | 09:12 PM
zsir's Avatar
zsir
The 351C uses the same mounts as a 302........Infact if you can find a 302 truck with a manual tranny the only things that you will need to chang is the bottom radiator outlet and figure out a exmanifold or header set up
Old Nov 13, 2002 | 01:43 PM
pward76's Avatar
pward76
[updated:LAST EDITED ON 13-Nov-02 AT 02:46 PM (EST)]That's what I was looking for! Anybody got a 70 - 72 that matches that description?
How does one change a radiator outlet? get a new radiator?
Old Nov 13, 2002 | 04:42 PM
gtex's Avatar
gtex
