Screw Back Seat Headrests
Old Apr 2, 2006 | 11:44 AM
carmk's Avatar
carmk
Can the back seat headrests on a 04-06 SuperCrew be removed? Anyone figured out how? I have three, yes three, child seats in the back of mine and the headrests keep the child seats from being positioned correctly in the back seat. Ironic since the I bought the Screw so that I could haul my family around!!
Old Apr 2, 2006 | 01:54 PM
GordoPanocho's Avatar
GordoPanocho
I'm pasting the following three (3) replies from other posts as I have no personal experience with removing the headrests. Good luck.
Pull it up, when it stops, on one side of the mounting feet you will see a flush mounted button, look close, push it in and continue to pull up on the headrest, it will release and come out. You can put it back in when not in use, since a seat without a headrest looks kinda crap. Hope this helps.
Do you see the notches on the inside of the chrome headrest support? Pushing in the button moves the lock from the notch. Push the button in (on the top of the seat at the base of the chrome supports, its the button on the plastic ring... to make sure we're all talking about the same one). And the headrest comes straight up and out. You may have to pull hard but that is the way you do it.
Just pull the headrest up until it stops and then push in on the little button on the left side while facing the back of the seat. Lift the headrest while pushing this in and it will pull out. I have to remove the rear ones for the kid's booster seats.
Old Apr 3, 2006 | 09:03 PM
carmk's Avatar
carmk
Thanks Gordo - really appreciate you digging this information up for me.
Carmk
eddiemoney
May 7, 2017 04:48 AM
Detstar8022
Mar 31, 2017 06:35 PM
fastang50
Nov 14, 2016 01:47 PM
ExplorerTominCO
1997 - 2003 F150
Aug 25, 2016 10:17 AM
Aaron285
Aug 7, 2016 07:02 AM
