1978 - 1996 Big Bronco
manual transfer case
Old Apr 1, 2006 | 11:19 PM
streetbeast's Avatar
streetbeast
I have a 94' bronco with push button 4wd and i want to put a manual shift transfer case in it. What do i need to know as far a wiring and the computers control on it if it does and anything else i need to know to make it work properly?
Old Apr 2, 2006 | 12:27 PM
greystreak92's Avatar
greystreak92
You need the manual version of the Borg-Warner 1356 transfer case along with the shift linkage and the boot that goes in the floor. The wiring harness will have the connector for the 4WD indicator circuit but it will be capped off with a plastic cover. The hole in the floor for the shifter and linkage is already in the truck under the carpet with a metal plate in place of the boot. Otherwise its pretty much a straight forward swap. The indicator circuit MUST be connected as the ECA (main computer) takes its information about the status (i.e. whether its engaged or not) of the 4WD from this circuit.
