Electrical Problem
Old Apr 1, 2006 | 10:49 PM
Rushmore X's Avatar
Rushmore X
Electrical Problem
Hello, I am searching to see if anyone has anything similar happen. I was coming down a steep hill and hit the OD off button. Immediately, all the guages on the dash turned off, and the engine went into idle. I had no control over the throttle, and had to coast the rest of the way into town. Any ideas?
Old Apr 2, 2006 | 06:36 PM
bmenzel's Avatar
bmenzel
Sounds like one of the wires where the shifter stalk meets the steering column is shorting to ground.
Do a search on previous posts.
Old Apr 3, 2006 | 05:44 PM
Rushmore X's Avatar
Rushmore X
Thanks, found the info and turns out that 's what the problem was.
Old Apr 3, 2006 | 05:48 PM
RubenG's Avatar
RubenG
Trent Fliginger, How did you fix it?
RubenG
Old Apr 4, 2006 | 12:51 AM
Rushmore X's Avatar
Rushmore X
There was an earlier post that said a similar problem was cause by the wiring harness for the OD off button mounted on the turn signal lever. The wire runs through the lever, and makes a tight, sharp turn where it exits. working the turn signal eventually wears through the insulation, causing a short. the new turn lever assembly has more slack in the wire, so this shouldn't happen again.
