1978 - 1996 Big Bronco
Window motor repair kit question
Old Apr 1, 2006 | 04:45 PM
autx790's Avatar
autx790
From what i've seen, the cheapest way to repair the power window motor is by replacing the 3 nylon bushings, at least thats all that appears damaged with mine.
On ebay, partzway appears to sel them the cheapest ($3.95). They all look exactly the same, but he's saying that different cars have different bushings and even the tailgate motor on a bronco is different then the other two. I have a 95 and from what his listings say, the only bushings he sells that are meant for 92-95 are the ones that also come with the gear for $15.
Does anyone know if these bushings are one size fits all? The cheapest i've found from auto parts stores around here is $20.
Old Apr 1, 2006 | 09:24 PM
Streetgang's Avatar
Streetgang
So far I have used the exact same ones on a 90, 93, and a 94 Bronco. As far as the TG motor goes.....well I would have to assume they are also the same, and BTW the TG motor will swap out with the LS door motor.
Old Apr 1, 2006 | 10:07 PM
greystreak92's Avatar
greystreak92
The difference is the compound of the Delrin used to make them. Because they are designed to handle windows of different sizes and weights, the compound is slightly different on say a set for a Bronco tailgate as opposed to the side windows. Its possible, since they are designed to crush at a certain pressure that using a set in the wrong location will yield premature failure when they shouldn't or no failure when they should crush.
Old Apr 2, 2006 | 07:35 AM
wdglide's Avatar
wdglide
They sell them for about $2 at most big name auto parts stores in the red HELP! sections. They fit 1965+ Fords.:
http://www.dormanproducts.com/docume...al.pdf#page=11
Old Apr 2, 2006 | 02:36 PM
autx790's Avatar
autx790
Thanks again guys. I went to autozone and sure enough they had them. Part #77410. They were $5.99 and now my window works
F-250 WARHORSE
Jan 7, 2017 08:34 AM
helo-tech
May 20, 2016 08:40 AM
Gary Lewis
677
Feb 2, 2016 10:58 AM
brendo613
Oct 22, 2011 06:13 PM
jarbeau
Jul 17, 2008 11:25 PM
