Truck running rich
Old Apr 1, 2006 | 09:44 AM
tuekwik's Avatar
tuekwik
Question Truck running rich
My 1991 F150 with a 351W is running real rich. I stand behind the truck and I can smell the fuel big time. Just replaced the injectors because the truck was parked for about 2 years. Took the spark plugs out and some plugs were white some were dark and some were half and half. Any ideas?
Old Apr 1, 2006 | 10:41 AM
TigerDan's Avatar
TigerDan
Check your fuel pressure regulator. Pull the small vacuum hose from the center and see if it has gas in it (it shouldn't.) If it does, then it's got a ruptured diaphragm. Also, check the pressure at the Schraeder valve (should be around 35-45 psi at idle.)
Old Apr 1, 2006 | 01:46 PM
tuekwik's Avatar
tuekwik
Replaced the regulator and I have about 42psi. One thing I forgot to mention the truck has a really sluggish take-off.
Old Apr 1, 2006 | 02:33 PM
TigerDan's Avatar
TigerDan
Have you pulled the codes?
Old Apr 1, 2006 | 06:11 PM
tuekwik's Avatar
tuekwik
That's the funny thing, no codes are coming out.
Old Apr 1, 2006 | 06:18 PM
TigerDan's Avatar
TigerDan
You mean the Check Engine Light isn't coming on, or you've actually put a code scanner on it and gotten no codes?
Old Apr 1, 2006 | 06:22 PM
tuekwik's Avatar
tuekwik
That's right.
Old Apr 1, 2006 | 07:03 PM
FghtinIrshNvrDie's Avatar
FghtinIrshNvrDie
I had this happen once. Rotten HEGO sensor didn't spit a code, because it was coated in carbon. So, it wasn't testing the air on the way out, ran it rich, and the same thing was happening.
Ryan
Old Apr 1, 2006 | 07:25 PM
tuekwik's Avatar
tuekwik
What did you do to fix that?
Old Apr 2, 2006 | 08:20 AM
FghtinIrshNvrDie
check your sensor before you go pay $40 for one. It's located in the exhuast pipe before they are joined into one pipe. There's a small connecting pipe between them, and the HEGO sensor is screwed into that piece.
Ryan
Old Apr 2, 2006 | 06:47 PM
tuekwik's Avatar
tuekwik
The sensor seems to be good, how would you know if it is no good?
Old Apr 3, 2006 | 12:35 PM
MrG4x4's Avatar
MrG4x4
Check the timing, and maybe even try to advance it a bit. If the timing is retarded to much, the spark will ignite too late and not have enough time to fully burn the fuel. This will give you a rich running engine that has no power and will definately be sluggish.
Old Apr 4, 2006 | 11:30 PM
tuekwik's Avatar
tuekwik
You are the man Mr.G, timing was way off, set the timing right and now I got take-off power. Thanks again.
Old Apr 5, 2006 | 10:29 AM
FghtinIrshNvrDie
ha! Awesome.
Ryan
Bronco 69
1966 - 1977 Early Broncos
16
Feb 18, 2013 12:16 PM
dwhackney
Jan 14, 2011 07:02 PM
roblalani
17
Feb 6, 2010 08:17 PM
78bigunns
Jan 12, 2006 07:34 PM
stryder
19
Aug 25, 2003 11:06 AM
