Painting the floor?
Where are you located, ie. does freezing temps affect the tile?
Did you prepare the floor in any fashion prior to the tile?
I assume you glued the tile and it wasn't a self-stick?
Any problems with it being slick?
Any problems cracking or chipping as the tile aged?
Thanks
I wish i had done this when i poured by shop floor.
The cost of doing this would probably be equil to all the work and supplies of painting. And the finish would last a lot longer with no maintenance other than washing.
The Best way though is still painting it.
To be able to sweep up on a slightly smoother surface is much better.
The problem with having it coloured is if the finisher DOESN'T know what they are doing ,It is a Wasted expense.
The concrete company will usually charge an extra premium
just because it is coloured and the driver has to completely clean the mixer for the next Un-coloured load.
Colour-crete is normally used for decorative purposes.
The reason I mention the finisher is :
Before you have a job done,MAKE SURE your finisher knows that under NO circumstances that water sprayed on the surface of the concrete to get a better finish.
This practise is the cause of many "Shaling surfaes of " garage floors,driveways,& sidewalks.
They shopuld make sure the slump of the concrete is of the proper slump at the beginning of the pour and they have enough men to carry out the job.
I don't know how many times in 23 years that i had to help out a contractor because he didn't have enough people to do the job.
Be careful out there.
[b][i][font color=red]Dennis[/font][i][b]
[font color=red]Calgary,Alberta,Canada[/font]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=green] Truck Data Plate Info
[/font
http://www.clubfte.com/users/mil1ion/FordTruckCodes.html
[font color=red]If New Ford Parts Is What You're Cravin',
Then Buy Them HERE,At Motorhaven![/font]
http://www.clubfte.com/users/mil1ion/Mil1ion.html
[font color=red]
Please Don't Ask Me Any Tough Questions,
"I'm Saving My Memory For When I Develop Alzheimer's" [/font]
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
641/2-Mustang 260,Pre-World's Fair Car.
64-Fairlane500 S/C waiting for a 390-4spd.
68-Mustang 289-Sunlit Gold 80,892Mi
[/font]
Check out the website [link:http://cti-corp.com/faqs.html|Concrete Technologies Inc.] if your interested or contact me via e-mail at
Krosati(No Email Addresses In Posts!) I can hook you up with a dealer in your area.
Something I havent really noticed here is the reccomendation of Vortex liner. It was originally made to be a spray in bedliner, but with proper preperation, it can easily be used on floors. It's installed by some professional people, and I think you can be back in your garage in two to three days. Truckin Magazine's October 01 issue has a full article on the material and installation. The whole issue is dedicated to garages, tools every do-it-yourselfer should have, both an Affordable garage, and the "Ultimate" garage. Check with www.primedia.com to get a back issue. Oh, and a friend of mine tiled his floor with the commercial grade checkerboard pattern for his cherry restored 64.5 'Stang, and it looks awesome. Anyway, hope this helps. John
Although I would like to paint/seal my garage floor, what am I to do with all the @#$* that has collected? ie; welder, torches, beer fridge, pizza oven, shelves, tool bench, table saw, innumerable kids toys, and such. Any advice, other than a sale!
, would be appreciated!
Pressure washed the garage, solvents where needed, and a fan & plenty of time to dry. Haven't had any problems. Then again, as far as garages go, mine sees very little abuse. Even used the same paint on my basement floor (without as much prep). A few spots have peeled slightly, but nothing some quick touch-up can't address. And as far as leaving things ouside, I live in a good neighborhood, on a dead-end sidestreet that only local residents & cops patrolling town travel. Wouldn't recommend this procedure for anyone who isn't as fortunate as far as location is concerned.
The only advice I can give SPFDRum is to put your stuff outside, and built an impromptu shed with some plywood & 2x4's. Make the shed size such that you can use full sheets of plywood & full lenght 2x4's without cutting down, and you can re-use the lumber for later projects. A quick cheap shed like this can be put together in about 2 hours if you know how to swing your tools and have a competent helper. Just remember that it's not a permanent structure & only needs to stay up for about a week, and you can get by with minimal expense. Use drywall screws instead of nails for quicker disassembly and less ruined lumber caused by crowbars.
I never had to put one of these together yet, but I once did a BBQ during turrential downpoars. I built a quick lean-to using my scrap lumber & plywood in half an hour -- covered over the back double-doors to the deck, the grill, and plenty of room to keep the grill away from the door. Took it apart the next day & used the lumber for another project. The BBQ was great, I stayed dry, and even had some company outside as the guys really liked my setup and preferred standing out near the grill while swilling their beers. I could tell you more BBQ stories about 110 degree weather, snow storms, weather below zero, BBQ in the garage, BBQ in the fireplace, etc. but I'm trying to keep my post on the topic... can you tell I love my BBQ's?
Right now half of it is carpeted owing to a friend who does trade shows dropping off a van load of *ahem.. unwanted* 10x20 pieces of bright blue carpet... Makes working on the ZRX1100 a pleasure.
