removing rust prior to welding?
Old Mar 31, 2006 | 09:28 PM
Flaflathead's Avatar
Flaflathead
I will be doing some light brazing. I will need to remove the rust. What would you suggest? The project is lower front fenders on a 52 F-1. I thought about a mixture of muratic acid and water. P.S., with the brazing, I will be using nickel silver rods. Thanks, Monte
Old Mar 31, 2006 | 10:26 PM
53fatfndr's Avatar
53fatfndr
Depends on how severe the rust is. If it is just surface rust, I usually just use sand paper or even a "wire-cup" in my 4.5" grinder. If the rust is eating through the metal, then I cut it out and patch it with some good metal.
Old Apr 1, 2006 | 07:38 PM
Flaflathead
Thanks, the rust in areas has eating through. I will be patching these areas. I thought that it would be a good idea prior to patching to clean away any rust, patch, prime and then smooth the rough areas with a filler, paint and be Happy!
WillyB
182
Dec 22, 2006 04:27 AM
j wright
Paint & Bodywork
Sep 25, 2005 08:06 PM
51fordrodder
Apr 6, 2005 07:52 AM
1985ColumbusF150
Garage & Workshop
Nov 28, 2004 06:14 PM
jkorreck
Garage & Workshop
Jul 11, 2004 05:56 PM
