injectors ?
Old Mar 31, 2006 | 06:05 PM
RobertJohn's Avatar
RobertJohn
Question injectors ?
OK..A dumb question !
How do you test injectors ? Do they show a code ?
Or what ?
Old Mar 31, 2006 | 11:47 PM
RobertJohn's Avatar
RobertJohn
anyone ?? i was sure someone would know.
Old Mar 31, 2006 | 11:49 PM
Kwikkordead's Avatar
Kwikkordead
What is your truck doing to make you question your injectors?
Old Apr 1, 2006 | 01:33 AM
RobertJohn's Avatar
RobertJohn
Low mpg...
rough idle and sounds like a miss...
Old Apr 1, 2006 | 07:47 AM
Kwikkordead
Originally Posted by RobertJohn
Low mpg...
That's why I am replacing mine. They will be here next week sometime.
Old Apr 1, 2006 | 08:44 AM
RobertJohn's Avatar
RobertJohn
But how do u test them or can you ?
It's very $$$$ to replace them all.....
Old Apr 1, 2006 | 08:51 AM
clux's Avatar
clux
If you have a dead miss, it can be diagnosed with an injector break out box.
Seems like other in-situ methods of injector diagnosis are pretty unreliable, even by the dealer. They really need to come out and be bench tested for much accuracy.
Old Apr 1, 2006 | 09:08 AM
RobertJohn's Avatar
RobertJohn
I assume there are different brands of injectors..
Is one better than the other ?? And what is a good one.
I'm really thinking about changing the drivers side first.. Due to $$$$
then the pass. side....Also the fuel pump and doing the HX SS cross over.
