alternator wiring ?
Old Nov 20, 2002 | 07:43 PM
dwayne93's Avatar
dwayne93
Post alternator wiring ?
i have recently obtained a 67 f100. someone else had started an engine swap and quit in the middle, leaving the alternator and other wiring hanging. i have three wires comming out of the firewall on the left hand side. assuming these go to the oil and temp sending units and the ign coil. there are no marking on the voltage regulator to distinguish which wire is what.
wire color
white with red stripe
black ( longest one )
red with white stripe
the alternator wire color
white with black stripe
white
black
red ( batt )
wire comming out of the voltage regulator
white
yellow
green with red stripe
engine is 300 6 cyl. i have been told it is the orignal engine
thanks ahead of time for any help
FORD!!!! need i say more?
Old Nov 20, 2002 | 08:55 PM
Mike W's Avatar
Mike W
alternator wiring ?
The voltage regulator is usually marked on the plastic insulator over the terminals. I, A, S, and F. The I terminal is spaced 1/4" more away from the other terminals. If you have the reg with the high top, you can replace it with a late 70's solid state regulator, has a cover about 3/4" high.
Connect the F to the fld term on the alternator. Connect A to the Bat+ on the solinoid. Connect S to a source that is hot when the key is on. The I term is not used unless you have a charge indicator lamp. The Bat term on the alternator goes to the Bat+ on the solinoid.
Old Nov 20, 2002 | 10:34 PM
Mil1ion's Avatar
Mil1ion
alternator wiring ?
midniteblue
1978 - 1996 Big Bronco
Aug 31, 2015 03:32 PM
79Supercab
Feb 22, 2015 10:16 PM
zingerr
13
Feb 9, 2014 08:29 AM
Murf77
Sep 12, 2011 09:34 AM
