289 Points
Old Mar 31, 2006 | 07:44 AM
stangfan78's Avatar
stangfan78
289 Points
I have a 66 289 that seems to consistantly burn up points. I can start the engine and let it idle and seems to idle fine. As soon as I put it in 'drive' it either cuts out or idles rough. When this happens I replace the points and it runs fine for months but slowly it will happen again. Anyone have any idea how I can troubleshoot this?
Thanks is advance
Old Mar 31, 2006 | 08:55 AM
TigerDan's Avatar
TigerDan
Have you replaced the condensor as well? Do you have a resistor in the system?
Most likely it's the resisitor, or the lack of one. A resistor, properly installed, lowers the voltage to the points when running (but giving full voltage when starting.)
I'm not sure about your 'Stang, but many Fords of that era used a resistance wire instead of a block-type resistor. Possibly it might have been replaced with standard electrical wire at some point, thereby removing the resistance value and giving full voltage to the points all the time...which will cause them to burn up.
Old Mar 31, 2006 | 04:34 PM
stangfan78's Avatar
stangfan78
Thanks for the help, can you tell which wire is the resistance wire?
Old Mar 31, 2006 | 06:06 PM
TigerDan's Avatar
TigerDan
The resistor, whether a ballast resistor or a resistance wire, is in the circuit supplying power to the hot (Batt.) side of the coil. A resistance wire is a replaceable wire that simply plugs inline before the coil with bullet-type connectors, and has (usually) a braided cloth loom over it. Or you could have the standard type ballast resistor, which looks something like this:
Old Mar 31, 2006 | 09:39 PM
stangfan78's Avatar
stangfan78
Thanks for the help.
Old Mar 31, 2006 | 10:52 PM
Dave Severson's Avatar
Dave Severson
Get a Petronix conversion kit, no more points, no more problems.
Old Mar 31, 2006 | 10:55 PM
stangfan78's Avatar
stangfan78
I thought about that. I just wasnt sure if what was causing the points to burn up would burn up the conversion module.
Old Apr 1, 2006 | 06:16 PM
baddad457's Avatar
baddad457
Thanks is advance
Welcome to the wonderful world of points. Your problem is why they don't use em anymore. A good set will last a year--tops.
Old Apr 2, 2006 | 07:35 AM
smallblock351w's Avatar
smallblock351w
You can put the pertronix in and if the resistor wire is bad it will not burn it out, my dad converted his 67 mustang to it, and it actualy says you can remove the resister wire for it if you want.
Old Apr 2, 2006 | 05:59 PM
jcp123's Avatar
jcp123
That Pertronix setup was sweet. Used them in my '68 Mustang DD and in our '67 Mustang Vert, it's a rock solid unit. Got better gas mileage, slightly better throttle response, and quite a bit more midrange torque. Can't comment on the resistor issue possibly affecting the control module though.
