housing cracked
Old Mar 30, 2006 | 11:09 PM
late70sfordnut's Avatar
late70sfordnut
housing cracked
as the title says i have a c6 out of a 78 150 4x4 and the housing is cracked the ? is i have a couple c6 2wd housings out of 70's models can i use the housing if i change all the guts and the tailshaft just wondering
Old Mar 31, 2006 | 05:37 AM
stuart1's Avatar
stuart1
If they share the same engine it should work.
You will have to do a side by each.
Old Mar 31, 2006 | 08:57 AM
mark a.'s Avatar
mark a.
Make sure the case you use has the 2 bolt holes for the neu/rev switch, some cases don't have them.
