Aerostar Ford Aerostar
Engine Squeak
Old Mar 30, 2006 | 04:22 AM
97EXT3.0's Avatar
97EXT3.0
Engine Squeak
Good Mornin' Y'all,
Does the 97 3.0L have the cam position sensor in it?
I have a belt like squeak coming from the engine, but it's not the belt. It does it even with the belt disconnected.
I have read the other threads on these forums and found the ones on the Ranger and Taurus 3.0's cam position sensors squeaking as they are dying.
The mileage is 124,000. About where the ones in the other threads were.
Just got back from a 1200 mile trip, at a pretty constant 75-80 mph without missing a beat. The day after we got back we got in it to go away and it howled like the alternator was locked up, for about 10 seconds, then it went away, now it chirps at idle, and goes away at about 1500 rpm. Read the thread about backfiring through the intake. Now it squeaks and backfires. As long as I don't make it accellerate faster than it wants to, it will work it's way up to speed and stay there quite happily.
I think I have the backfire figured out, I just need the time to finish troubleshooting it to eliminate a wiring problem before I go spending money on expensive parts.
Anyway, does the motor in my 97 have a cam position sensor in it that will squeak as it dies?
Thanks for the time
Steve
Old Mar 30, 2006 | 02:18 PM
96_4wdr's Avatar
96_4wdr
yes, it does have a cam position sensor, located at rear top of engine on vertical shaft that extends down into engine and gear engages cam shaft gear on rear of cam shaft...remove dog house cover to access....not fun to change
never have heard one "chirping"
use a section of garden hose as stethascope to listen to different parts of engine to pinpoint "chirp" location
since you have a newer OBDII system, put it on an OBDII scanner and monitor timing and cam shaft sensor signal at steady 1.5k rpm for any intermittent changes
cam position sensor requires special installation alignment tool, some parts stores carry a loaner or buy one
Old Mar 30, 2006 | 06:51 PM
wresleu's Avatar
wresleu
I am currently experiencing the EXACT same condition. I have isolated it down to the water pump. I would venture to guess that is your culprit as well, they seem to fail pretty regularly in my experience (8 aero's in 10 yrs, all cargo's though). Water pump is pretty cheap $35 and a bit of a pain to change, but a DIYer can easily do it.
Old Mar 30, 2006 | 08:16 PM
96_4wdr's Avatar
96_4wdr
97EXT,
also pull OBDII codes from PCM....camshaft sensor failing oftens sets a code...
read both KOEO & KOER
don't drive until backfiring problem solved....can break or bend crankshaft, rod or wristpin
provosc
32
Dec 1, 2017 12:59 PM
ranger817
1983 - 2012 Ranger & B-Series
Dec 23, 2012 09:13 PM
danpayton
Apr 7, 2009 07:29 AM
spoon059
Mar 5, 2003 08:39 PM
