pitman arm
Old Nov 23, 2002 | 09:07 AM
spr1049nc04's Avatar
spr1049nc04
pitman arm
Wher the heck can i find a pitman arm for a 72 f100 v8 auto??
Old Nov 24, 2002 | 08:19 AM
jds1971's Avatar
jds1971
pitman arm
Your best bet is a salvage yard.
Is yours damaged- If I remember correctly, the ball and socket are on the draglink- so there shouldn't be any need for replacement.
I wouldn't be afraid of putting a little heat to it and bending it back into shape if it was bent.
Hope this helps-
Joe
Old Nov 24, 2002 | 12:34 PM
spr1049nc04
pitman arm
Than it might be the drag link. the is quite a bit of play at that pint in the steering.
Old Nov 24, 2002 | 01:12 PM
jds1971's Avatar
jds1971
pitman arm
You should be able to find all your front end parts at your local parts house. I think I got everything to do mine from O'Reilly's. What they didn't have in stock they were able to get the next day.
Joe
Old Nov 24, 2002 | 07:40 PM
wisnowman's Avatar
wisnowman
pitman arm
"Salvage Yard...........this is a non-wear item and is no longer produced" is what I've been told.
Good Luck
Dave
Old Nov 25, 2002 | 01:11 AM
big_country_ch19's Avatar
big_country_ch19
pitman arm
are the pitman arms the same from 69-75? is yours m/s or p/s?
I have a 69 m/s avalible
Old Nov 25, 2002 | 07:19 PM
spr1049nc04
pitman arm
It is a MS 72 with v8 and auto 4x2. i beleive the 67-72 are pretty much the same. m front end shimmies and the paly seems tho be pitman arm drag lin area.
Thanks
Old Nov 26, 2002 | 02:21 AM
big_country_ch19
pitman arm
whats the going rate for the pitman arm and drag link? and if you wanted it, how soon would you need it.
Jack
Old Nov 26, 2002 | 06:09 AM
jowilker's Avatar
jowilker
pitman arm
Is your pitman arm bent? If not there shouldn't be any reason to change it. I believe all of the 2wd arms are the same, 65-79.
http://www.clubfte.com/users/jowilker/USFlag.gif
John
jowilker email me
[link:www.ford-trucks.com/users/jowilker|My Club FTE Page] Member 0004 since 01 01
[link:www.ford-trucks.net/users/jowilker/NCFTE.html|NCFTO] North Carolina Ford Truck Owners Group
In the cool still quiet of night, you can hear chevies rusting away.
Old Nov 26, 2002 | 06:17 AM
Huntsman's Avatar
Huntsman
pitman arm
[updated:LAST EDITED ON 26-Nov-02 AT 07:18 AM (EST)]The pitman arms are different, power steering and manual steering will not interchange. The shaft from the steering gear box is larger...or is it smaller on the power steering unit. When you get the pitman arm from the junk yard, don't forget to get the nut and lock washer. Happy Thanksgiving!
Old Nov 26, 2002 | 01:16 PM
William's Avatar
William
pitman arm
Check the rag joint for wear and play. Check the lower steering column bearing for wear or play. Then replace the steering link and both ends of the tie rod. Pitman arms do not wear out. They can be bent but usually there isn't much truck left after that happens. Post back!
William in Atlanta
Old Nov 27, 2002 | 09:06 AM
spr1049nc03's Avatar
spr1049nc03
pitman arm
I am putting it on a lift today to che it our and see exactly where the play is coming from. it is hard to really look at it in your back yard.
Old Nov 27, 2002 | 01:02 PM
Mil1ion's Avatar
Mil1ion
pitman arm
Old Nov 27, 2002 | 03:31 PM
spr1049nc03
pitman arm
It is in the steering box. i had it on the lift and the pitman arm and drag links had no play in them. Ther was a little play when I tried to shake the top and bottom of the tire, and a little left to right. but there was no play in the arm drag link or rod ends.
Hyperactive460
WTB - Parts & other
Nov 21, 2015 06:33 PM
STGFordCrazy04
Nov 15, 2007 07:06 PM
yama766
Mar 25, 2006 09:03 AM
Carlene
Aug 2, 2002 02:11 AM
BB
Mar 29, 2002 08:22 PM
