OK, i hope this makes sense.....you can put that distributer about anywhere you want as long as certain things inside line up right...with the piston at TCD, note where the rotor bug is pointing as compared to a solid object on the motor somewhere, now slowly pull the dizzy up until it clears the gear then turn the rotor bug counterclockwise about 2 or 3 teeth...basically, stab and restab the dizzy until the rotor bug points at the number one plug wire with the VA facing forward( maybe slightly to the driver side)..when u get that part, remove the rotor bug and look at the pickup prongs at the base of the dizzy shaft under the rotor, it should be lined up with the little rectangular contact of the pickup coil in the dizzy.....if they arent restab until you get it right on with the dizzy sitting how you want...if that reluctor isnt matched up it throws your timing way off...if it still gives you fits, restab the dizzy one tooth at a time each way( keeping track of how many teeth you move it) until you find that sweet spot....
I do not believe that the wires are in the wrong position relative to the distributor. Moving them one postion counter clockwise only forces the VA to need to be moved more to the left. It is already as far to the left as it can go.
I posted a better picture of the distributor, showing the #1 marking on the cap:
BTW, thank you, and everyone you has provided to this thread. I appreciate your expertise. I drove the truck today, but it does not seem right; it doesn't backfire, but does stutter very subtlely between 30-50 mph.
Okay, you've got your wires on wrong. The #1 plug wire needs to go onto the post directly below where it is now, not the coil post, but the one that is exactly one position clockwise. This will reorient the distrubutor to where it should be.
I did move the plug wires, it could be that the '#1' stamp is in the wrong place. It did allow me to move the VA more toward the center of the engine. I found something else; once the motor is at normal operating temperature, I do not feel any suction from the hose going to the VA. Also, at normal operating temperature, the timing is the same (i.e. it does not change) with the hose on or off. I am beginning to thing that the hose tree on the intake manifold becomes obstructed when the motor is hot. Is this possible?
The VA is on a thermal vacuum switch, its supposed to be off when warm..ithe VA helps the motor run smoother when cold, and isnt really needed when warm..at least its that way when the motor is in tiptop shape anyways....did you check the pickup coil reluctors under the rotor bug with the dizzy pointing at #1???
