Driving with O/D on....
Old Apr 4, 2006 | 11:37 AM
gatesj's Avatar
gatesj
Originally Posted by dhag911
depends on your speed if you are going to be driving between 30-40 a lot then shut the OD off. if you are going to be going up some hills at around 35-40 shut it off. but if it is flat and you keep a continuous speed above 35 turn the OD back on.
Basiclly whenever your speed drops to 34 it will kick out of OD.
That depends on rear end ratio. I had a 3.08 rear end truck that kicked out at 45. That ratio sucks.
