New Idea for Regulated Fuel System
#46
Originally Posted by John7894
Kwik,
What advantage did you gain by moving the pump closer to the tank?
Same principle as a deep water well pump. The pump is at the bottom of the shaft not at ground level.
#47
What Kwik cited is a good example.
The suction of even a "perfect vacuum" will only lift a liquid just so far (it varies according to the specific gravity of the liquid).
Given enough pressure, you can PUSH that same liquid a LONG way into the air.
Pop
Pop
#48
Originally Posted by Tenn01PSD350
OK Sir, would you be so kind as to elaborate or will you be donning the asbestos suit? You've got my attention.
Originally Posted by Kwikkordead
Yes to put a fine point to it, I've given it an alternative exit instead of having to go out through one of th injectors.
However........
Just past the outlet of the oriface I installed a clear bodied fuel filter that I am using as a sight glass. It's very easy to spot the air bubbles that pass through the oriface and back to the tank. I've done the Hutch mod to my tank pickup, gotten rid of the quick connects from the tank pickup to the fuel pump, and also relocated the fuel pump to the rear of the truck right next to the fuel tank.
The only time that I ever see air in the fuel anymore is right after I change the fuel filter. Ten minutes after I start the engine there is nothing in the sight glass but crystal clear fuel. I can safely make the claim that there is no air in my fuel supply. No air in = no air out.
You are also assuming that all air in diesel fuel is visible...wrong again! Just because the fuel looks clear doesn't mean it's free of air.
I'm not knocking what you've done, just trying to correct your assumptions about the effectiveness. It is totally unrealistic to think you can remove all air from diesel fuel, all you can do is make mods to try to limit it as much as possible.
#49
A few questions come to mind.
One) I would assume that international would have a say on what's done to they're engine and if Int supplies a regulated return system to rid the heads of as much air as possible, then why would Ford remove it? Cost? Jeez for a 6k upgrade whats a few hundred more?
2) the pulsation that Kwik mentions is very real and possibly problematic. the pressure spike is instant and hydraulic pressure spikes can cause fluctuations in flow delivery. Has anyone thought of using a precharged chaber similiar in the plumbing industry. They are called water hammer surge arrestors. They are precharged with 50 or 60psi with a captive air chamber isolated by a muti o-ring piston.
I'm wondering if they would dampen the fuel pressure spike.
#50
Here is what I'm taking about - not sure if the orings are #2 fuel rated?
http://www.pppinc.net/whasweaton.htm
#51
For Kwick - look at some of the ways that air entrainment can be caused.
http://www.machinerylubrication.com/...oup=Hydraulics
#52
Various sources of bubble formation within the hydraulic system include:
1. Suction resistance
2. Pressure drop through an orifice
3. Pressure drops through pipes and hoses
4. Turbulence from valve opening and closing
5. Shock waves due to sudden closing of valves and sudden cessation of pump operation
6. Pressure drop due to sudden opening of a valve
7. External force on piston rod
8. Plunging of fluid at the return to tank
9. Inadequate net positive suction head available (NPSHA) relative to the net positive suction head required (NPSHR) in centrifugal pumps
10. Suction-side recirculation to sub-best efficiency point (BEP) operation of centrifugal pumps
11. Nearly dry operation of a pump due to insufficient fluid volume.
#53
Originally Posted by AGruenke
Flame away if it makes you happy, it won't hurt my feelings.
Yes, you have provided another place for fuel/air to exit, but if there is air in the fuel, there is nothing in your system that guarantees that it won't take the path through the injector instead of out the end of the head.
You're still making assumptions. You're assuming that you have "no air in", not a safe assumption at all. I'm not saying you didn't help the situation, you've certainly done a number of things to limit the amount of air intrusion, but there is still air in the fuel. Even an AirDog or Fass can only remove ninety-something % of the air, nothing is 100%.
#54
#55
Are you guys aware that there is a HUGE amount of information about this subject at the other forum site? This stuff has been worked on for several years. There are even high quality fuel system kits available that take the guesswork out of the installation.
I would have purchased one of those kits if I wanted to spend the $$$$.
I preferred to save my money and spend it on toys.
#56
#57
Originally Posted by clux
But where's the fun if all the parts come in the same box with instructions? May as well just take it down to the local speed shop and let someone else put it on.
#58
I looked at several systems before building my own. In fact, building my own wasn't much cheaper than one, say from ITP. However, the parts I used weren't the cheapest and it could be done for a lot less. The one thing my system has over the ITP system is larger lines - 6AN on mine vs 4AN on the ITP system. Plus, I liked the idea of doing it myself. I'm a big DIY type of guy, and actually preferred to design and assemble the system myself.
#59
Fun stuff looking around Jeg's and Summit racing for parts to get the job done.
Nut
#60
