New Idea for Regulated Fuel System
#61
Originally Posted by monsterbaby
Oh I am dangerous when I start looking at summits web site, and the one time I had a load out to Ohio and had to layover one night I spend like 7 hrs in thier store, kinda like a kid in a huge candy store and managed to get out of there for slightly over $500 so not bad.
![Goofy Laugh](images/smilies2/hihi.gif)
Nut
#62
Originally Posted by clux
Which one? Are you aware that there are at least 4 other 7.3 forums on the web? you need to be more specific. If you are talking about TDS, yea, I think most of us are aware.
Actually it has been worked out since basically the inception of the engine. Are you aware that the regulated return fuel system emulates an International fuel system that Ford chose not to use?
You mean like Bob Riley's CPR systems or ITP's regulated return system? How about Diesel Innovations regulated return system, were many of us buy parts for our own version? Yeah, I think most of us are aware of those sites. But where's the fun if all the parts come in the same box with instructions? May as well just take it down to the local speed shop and let someone else put it on.
![Shaking Head](images/smilies2/rotz.gif)
#63
#64
Originally Posted by jtharvey
I looked at several systems before building my own. In fact, building my own wasn't much cheaper than one, say from ITP. However, the parts I used weren't the cheapest and it could be done for a lot less. The one thing my system has over the ITP system is larger lines - 6AN on mine vs 4AN on the ITP system. Plus, I liked the idea of doing it myself. I'm a big DIY type of guy, and actually preferred to design and assemble the system myself.
#66
Originally Posted by AGruenke
Same reason they have gone to a returnless system on Mustangs and other cars too...EPA!
However I fail to see the connection to a diesel. Diesel doesn't evaporate like gasoline does. I think the engineering dept. is designing without really thinking.
#67
#68
Originally Posted by Kwikkordead
You're spot on there. A returnless fuel system on a gasser generates a lot less HC vapor.
#69
Originally Posted by Tenn01PSD350
Soooo, what system did you opt for and what truck is it in?
#70
My 2001 had an ITP kit (was called JNB when I got it several years ago). ITP is local to me and I've been talking to them about fuel system mods for my 6.0L too. Those are on the drawing board, but it sounds like they will be a while.
Where can it be found?
#71
I've looked at all of the currently available "kits" and talked to a lot of people. 6AN hose isn't necessary, I know of at least one 600hp Ford running 4AN regulated return fuel lines. Nothing wrong with running bigger, but its certainly not a criteria when selecting a kit or parts...
![Wink](images/smilies/wink.gif)
![Smilie](images/smilies/happy0161.gif)
#72
DPP is working on a kit for the PSD's that will eliminate the factory LP....where it goes from there......
The Cummins (HPCR) market is needing high pressure and flow for the modded CP3 High pressure pumps. So now they have FASS pumps that can produce 80+ psi all day long with out burning up....this might be a good combo with the regulated fuel return........
![Okay!](images/smilies2/thumb.gif)
#73
