Offroad & 4x4
welder
Old Mar 30, 2006 | 08:32 PM
r0n1n's Avatar
r0n1n
am i mistaken in thinking that the MIGs are easier to use than the arcs?
Old Mar 31, 2006 | 02:39 PM
vman's Avatar
vman
Mig is easier than ars,but if you learn to arc weld you will be able to mig in your sleep.
Old Mar 31, 2006 | 04:27 PM
chrono4's Avatar
chrono4
if you have someone set it up right for your metal, it is easier. mig is constant speed fed, so you dont have to push down, just move in circles. the getting the heat and wire speed is pain.
Old Mar 31, 2006 | 05:41 PM
proeliator's Avatar
proeliator
This is true. The other thing is, with a mig a novice can lay down a bead that looks pretty decent but has the penetration and strength of monkey poo. It can be very deceptive. With arc welding, when you've laid down a crappy bead you KNOW you've laid down a crappy bead. I learned oxy/acetelyne first, then arc, and finally mig. Basically, from hardest to easiest. Sounds weird but I think its the way to go. Again, with your desired usage and level of coin you want to spend, go with a good arc welder and find somebody to help you learn how to use it.
Old Mar 31, 2006 | 07:59 PM
go_racing84's Avatar
go_racing84
The nice thing about taking a welding class is that your stuff will get pressure tested and you will know exactly the difference between a good and bad weld, strength-wise. I took basic metals in high school, and though I really didn't do much welding until a couple of years ago, when I did pick up a MIG, I had an idea of what was strong and what wasn't. Community colleges have basic welding classes for the public, I'd say check out one locally before you even buy a welder.
Old Apr 1, 2006 | 11:51 PM
WunTunEarlyBKO's Avatar
WunTunEarlyBKO
just get 3 or 4 batteries and a couple sets of jumper cables and call it good!
Old Apr 2, 2006 | 06:53 AM
tjc transport's Avatar
tjc transport
i ain't rite
that ain't nuthin more than a really cheap arcwelder.
Old Apr 2, 2006 | 11:59 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
dont waste your $$ on a little welder....if your only going to have one welder, at least get one that can handle 1/4" AT LEAST
i would suggest a lincoln AC/DC stick welder...225 amp, the dc is soooooooo smooth, and you can weld anything you will ever want on ac....they are cheap as well
Old Apr 2, 2006 | 12:04 PM
ivanribic's Avatar
ivanribic
Good call KO, that's what we used at the house forever as the MIG went to the shop. They're pretty cheap new, dirt cheap used and can be found anywhere. They also last a lifetime.
No shipping available but just to give you an idea: http://cgi.ebay.com/Lincoln-Arc-Weld...QQcmdZViewItem
Old Apr 2, 2006 | 01:59 PM
KubotaOrange76
i would really suggest coming off the hip and getting one with ac and dc capability too, i didnt and im kicking myself for it, i paid 225 new for my lincoln 225 ac stick, i think the ac dc was still under 300 brand new?
Old Apr 8, 2006 | 12:13 AM
r0n1n's Avatar
r0n1n
what's the difference between ac and dc?
-jason
