Pyrometer & Boost Gauge illumination
Old Mar 28, 2006 | 09:27 PM
papa737's Avatar
papa737
Exclamation Pyrometer & Boost Gauge illumination
I install a Stewart Warner Pyrometer and Boost guage the illumination is much brighter in the Prometer than the Boost Gauge. I tied both Gauges into the yellow illumination wire . Both are grounded in the same ground. Does any one know why one should be brighter than the other. Both have the same lamp size. The boost guage is the same brightness as my dash lights. When I dim the lights the boost and pyrometer dims but the pyrometer is still brighter.
Old Mar 30, 2006 | 07:13 AM
Tdusseau's Avatar
Tdusseau
Swap the wires and see if there is a change. If no change and the pyro is still brighter..Well call stewart warner and speak with someone in the tech dept.
Old Mar 30, 2006 | 10:37 PM
papa737's Avatar
papa737
I called Stewart Warner the Tech told me that electrical gauges are brighter than mechanical gauges. Suggested I go to Radio shack and get a bulb with a lesser illumination. I will try to switch wires first and see if that helps.
