Deactivating Keypad Remote
Old Mar 28, 2006 | 02:31 PM
ronmartin27's Avatar
ronmartin27
Question Deactivating Keypad Remote
I recently purchased a used 2005 Expedition locally and wanted to know how to deactivate the keypad remote locks. I called the dealership and was told that I couldn't change the permanent code set by the factory, thus if someone knows the code, they'll always have access to the vehicle. Is this true? I know you can add a personal code, but it doesn't override the factory code.
Therefore, is there a way to disable the keypad so it can't be used any longer?
Thanks for all your help!!!
Old Mar 28, 2006 | 04:45 PM
FTE Herman's Avatar
FTE Herman
Hey Ron, welcome to the site! If there is a way to turn off the factory code, I'm not aware of it. Someone else may poke their head in here and say differently. Let's see what happens.
Old Mar 29, 2006 | 12:13 AM
skier-24's Avatar
skier-24
How about a fuse? Or remove the door panel and pull the plug?
Old Mar 29, 2006 | 12:27 AM
the4by4freek's Avatar
the4by4freek
once you overwrite the factory code it won't work unless you disconnect the battery to erase your new code.
