Help With 90 F250
Old Mar 28, 2006 | 11:41 AM
Rich33's Avatar
Rich33
Help With 90 F250
I've got a 90 F250 4x4 with a 460. I recently changed the engine out with a fresh low mileage 460 from the same year truck. I worked out all the codes and the truck seems to be running fine, but now the CE light is coming back on from time-to-time. It's popping a 565 code (canister purge circuit failure?).
Can anyone help me determine what to do next to get this code to clear? Thanks, this site's been a big help already with this project.
Old Mar 29, 2006 | 08:55 PM
95X15's Avatar
95X15
Take out the canister purge valve - see if it will hold vacuum in closed, de-energized position, if so good. Then with vacuum applied jump 12 volts to connector red lead and ground grey/yellow lead (fron 88 manual - hope it is same on 90) and vacuum should bleed off should be able to cycle valve with voltage and it should move quidkly.
Hope this helps.
samsdad02
Jun 20, 2012 05:09 AM
tandpr
1983 - 2012 Ranger & B-Series
May 8, 2009 06:33 AM
dixokai
Nov 28, 2007 01:06 PM
velocity
Aerostar
Aug 5, 2006 12:22 AM
mrblue01
Mar 5, 2003 03:08 PM
