Belt Question???
Old Dec 6, 2002 | 04:20 PM
kdouthit's Avatar
kdouthit
Belt Question???
I went to the local parts store to pick some goodies for my 67 F100. Fan belt looked to be in bad shape so I thought I would replace it while I was at it. The counter guy said the 352 required 2 belts, but mine has only one. He suggested the engine might have been replaced. Any ideas?, The truck was my granfathers and has been in my immediate family since new, and I am not aware of any engine replacement.
Old Dec 6, 2002 | 04:28 PM
BB's Avatar
BB
Belt Question???
You do need two belts, one to put on the motor and one to carry as a spare! The counter guy is full of crapolla.
BTW, welcome to the site!
Barry
Old Dec 6, 2002 | 04:37 PM
kdouthit's Avatar
kdouthit
Belt Question???
Thanks for the info, and the welcome.................
Old Dec 6, 2002 | 04:48 PM
karlsd's Avatar
karlsd
Belt Question???
Depends on the accessories. If you have power steering and A/C, you need three belts! Only one is a "fan belt", however.
Old Dec 6, 2002 | 05:03 PM
BB's Avatar
BB
Belt Question???
That's what I'm talking about Karl. Some engines, especially high-performance engines did double-up on the fan belt though.
Barry
Old Dec 6, 2002 | 05:59 PM
Triple Threat's Avatar
Triple Threat
Belt Question???
My 390 on my F100 takes TWO fan belts. I am sure it would work fine with one, but I replace them both just the same. Then again, my 390 came out of a 69 Torino.
Old Dec 6, 2002 | 06:04 PM
mk's Avatar
mk
Post Belt Question???
The F250/350 ran a matched set...
Old Dec 7, 2002 | 11:03 AM
sullyda1's Avatar
sullyda1
Belt Question???
[updated:LAST EDITED ON 07-Dec-02 AT 12:05 PM (EST)]My '67 came stock with 2 matched belts for the crank/water pump/alternator. The belts used to be sold as a set. The alternator had a 2 groove pulley. Somewhere along the way I changed to a one groove alternator pulley, so I now I run one belt. Does not seem to have made any difference. I also have a separate belt for the power steering.
Old Dec 7, 2002 | 11:40 AM
kdouthit's Avatar
kdouthit
Belt Question???
Thanks Sulldal,
I got to looking at it last night. I'm pretty sure when the alternator was replaced, they went to a one belt setup just like you did.
Old Dec 7, 2002 | 12:28 PM
BB's Avatar
BB
Belt Question???
Hmmm...so a '67 F100 could have had dual belts too. Looks like it's not the counter guy that's full of it. Sorry about that, will update my notes. Thanks guys!
Barry
kdouthit, I take it your crank and water pump pulleys have two sheeves and you're only running the inside one?
Old Dec 7, 2002 | 01:09 PM
big_daddy_velvet's Avatar
big_daddy_velvet
Belt Question???
I have a 352 in my 72. Should I be running a belt from my crank to my water pump, and a seperate belt for my alternator? I have P/S, and I am running 2 belts, but there is a 3rd sheeve on both my water pump pulley and my crank pulley. Is that just an extra, or is it essential?
BDV
Old Dec 7, 2002 | 02:28 PM
banjopicker66's Avatar
banjopicker66
Belt Question???
Old Sep 6, 2006 | 02:08 PM
1972-34ton's Avatar
1972-34ton
Rabbit-Hole Researcher
Thumbs up Double belt on '72 3/4 ton
I have a double Fan/Crank/Alternator belt on '72 3/4 ton.
Kevin
Old Sep 6, 2006 | 05:47 PM
jowilker's Avatar
jowilker
Hey Kev, Couldn't you find anything newer that 2002 to reply to??
John
grider
6.4L Power Stroke Diesel
15
Dec 11, 2019 11:59 AM
click2001f350
Mar 13, 2014 04:03 PM
gtadim
Jan 22, 2014 05:43 PM
asmith68
Jul 23, 2007 09:53 AM
fordeg2003
1983 - 2012 Ranger & B-Series
Dec 20, 2004 06:53 PM
