converter
Old Mar 27, 2006 | 07:19 PM
burge743's Avatar
burge743
converter
any ideas on replacing the factory cat.my is shot.the new ones are around $400.00.do not really want to spend that much on one.
Old Mar 27, 2006 | 07:29 PM
Popa Tim's Avatar
Popa Tim
a y-pipe and a universal Hi flow from CatCo should work great.
Old Mar 27, 2006 | 10:51 PM
someday's Avatar
someday
check out summit racing
Old Mar 28, 2006 | 07:07 AM
handyman43358's Avatar
handyman43358
Do they sell Y pipes that will bolt up to the manifolds on our V8's?
Sorry I'll stop hacking this thread and make a new one.
Old Mar 28, 2006 | 10:40 AM
fordman16b's Avatar
fordman16b
solution
Hollow the factory cat out located inside the y pipe. Then install an aftermarket cat after the y pipe. It will save you a lot of money and work just as well.
Old Mar 28, 2006 | 01:17 PM
1992flareside's Avatar
1992flareside
What size motor? If it is a 5.8L go to Autozone,$173.00.,made by Maremount,Carquest wanted $250.00
Old Mar 28, 2006 | 04:23 PM
water 5's Avatar
water 5
check out www.genuinefordparts.com and what is your motor size?
