flex plate/damper problems
Old Mar 27, 2006 | 12:16 PM
maverick82's Avatar
maverick82
does any one have the pecs on the weight size (l/h/w) for the 28oz and 50oz flex plate and how to tell what damper i have? engine vibrates bad. the engine is supposedly out of an 83 t-bird. didn't they change balances in this year? could it be that it is an 82 motor in an 83 body? i didn't see the car it came out of to see wether or not is was made in late 82 and sold as an 83. any help appreciated.
thanx
Old Mar 27, 2006 | 02:57 PM
Flyn66dtmn's Avatar
Flyn66dtmn
at the risk of sounding real stupid what is a flex/plate??????
Old Mar 27, 2006 | 04:51 PM
banjopicker66's Avatar
banjopicker66
Maverick82, WELCOME to FTE, a great Ford truck site!
I suggest you try posting this question in the '80s forum; they will be more likely to know the answer.
However, what motor are you talking about? Is it a Windsor? A 385?
Flynn66: A flexplate is the flywheel equivalent for an automatic transmission. The torque converter bolts to it.
It is not a flywheel because it doesn't perform the function of a flywheel, which is to provide inertia to keep the engine spinning and balanced. The torque converter does that instead, for an automatic transmission setup.
Old Mar 27, 2006 | 06:46 PM
BobbyFord's Avatar
BobbyFord
Sounds like the balancer spun to me.
Old Mar 28, 2006 | 11:10 AM
barry's Avatar
barry
Certain flywheels in combination with the dampers on 302's will cause the problem you're describing. Common problem in the 80's It throws the whole thing out of balance.
Barry
Old Mar 28, 2006 | 11:44 AM
Flyn66dtmn's Avatar
Flyn66dtmn
learn sumthin new every day,been changin them out for years and never knew they had a different name than a fly wheel. thanks
Old Mar 29, 2006 | 04:47 AM
jowilker's Avatar
jowilker
So, You just thought you were a knowitall, huh??
John
Old Mar 29, 2006 | 12:52 PM
garbz2's Avatar
garbz2
Actually a ford parts man will look at you quizzically when you ask for a ford flex plate...
they call them flywheels. Manual or automatic....LOL
385 in a Cougar? Banjo what are ya thinking there...LOL
50 OZ typically is used for the AOD application.
Garbz
Old Mar 30, 2006 | 03:51 AM
jowilker's Avatar
jowilker
Hey Dave, You didn't mention that he tried to run him off to another forum, like we can't deal with it. Somebody needs to get a little keen switch and stripe his legs.
John
Old Mar 30, 2006 | 06:34 AM
garbz2's Avatar
garbz2
Man Brother John I can almost hear the swoosh. ROTFLMAO.
Garbz
crazy96863
Apr 12, 2013 01:39 PM
crazy96863
Feb 17, 2013 12:57 PM
mauicruza
26
Dec 24, 2012 08:02 AM
mike83f250
Nov 6, 2011 08:10 AM
daphill
Dec 21, 2010 02:44 AM
