PSD 4x4 front hubs !
Old Mar 27, 2006 | 10:22 AM
RobertJohn's Avatar
RobertJohn
I need to change my pass. side front hub on my 4x4..
NAPA carries them but are they guaranteed for life just like their other parts ?
And do they stock the other parts necessary, like to latge yellow "O" ring and large seal ??
I remember someone on here commenting on it but can't find the link.
Thanks
Old Mar 27, 2006 | 11:10 AM
SpringerPop's Avatar
SpringerPop
Nope. Yellow o-ring is a Ford item, along with new studs (highly recommended).
O-ring: F81Z-4A322-AA
Studs (you need four): F81Z1107-AA
Total for the Ford parts is around $20.
You likely will be able to re-use the outer "hub lock" seal, but if it does eventually need replacing, it's just a snap ring's removal away. No "complete dissassembly" to get to it, like the yellow one.
You should also have some wheel-bearing grease around, too, for this job.
I didn't need to replace the shaft seal, as mine was still good, so I can't comment on the price, procedure, or difficulty.
Pop
Old Mar 27, 2006 | 05:01 PM
mjtpolice76's Avatar
mjtpolice76
is there any general maintence I should be doing to prevent premature failure
Old Mar 27, 2006 | 06:09 PM
RobertJohn's Avatar
RobertJohn
My main question is this ??? Are the NAPA hubs guaranted ???
Or does anyone know ???
eldorado73
Jan 21, 2012 08:16 PM
adworden
Feb 19, 2011 07:00 PM
rpatrick
Aug 26, 2009 06:47 PM
Smiley Pete
Aug 19, 2007 08:56 PM
