Trailer plugs
Old Mar 27, 2006 | 09:49 AM
tenptbuck7mmmag's Avatar
tenptbuck7mmmag
Trailer plugs
Hey,
To start with I have never been any good at hooking up trailer lights.
But I always try.
This time my brothers small trailer is the progject.
His trailer has 5 wires :1. Green 2. Green Brown.3. Yellow 4. Yellow Brown 5.White
But he has a 4 wire plug.
The plug has 1. White 2.Brown 3.Yellow.4. Green
Please help, I'm not sure how what wires to put togeather.
Sounds simple but like I said I've always been bad at wireing trailer lights and have blown afew fuses.
THANKS
Old Mar 27, 2006 | 10:04 AM
blockheadbob's Avatar
blockheadbob
trailer wiring:
First thing you need to do is find out what wire goes where. Use a 12 volt tester on the vehicle and a 12 volt power source on the trailer. You are going to have to either make an adapter to go from the 5 wire plug to the 4 wire plug or you could replace both of them with a new plug system.
Bob
Old Mar 27, 2006 | 10:07 AM
Franklin2's Avatar
Franklin2
Standard wiring is:
Green = right turn/brake light
Yellow = left turn/brake light
Brown = running lights
White = ground
I can't find anything with your color code. The only thing I can find about 5 wire trailers is they are usually equipped with surge brakes. Does this trailer have surge brakes? They say with a 5 wire system, the extra wire goes to the back-up lights of the tow vehicle. This 5th wire sends a signal to disengage the surge brake system so you can back up without the brakes on the the trailer locking up.
The only recommendation I have for you is to find a small battery charger. Hook the - to the trailer frame and start testing. One of the wires should be ground (the white one?) so when you touch this one, you should get a short. This should not hurt the battery charger though, since it has a circuit breaker in it that will reset. That's the great thing about it, you can figure it out without blowing fuses, and see what wires do what.
Old Mar 29, 2006 | 04:28 AM
ncranchero's Avatar
ncranchero
Standard trailer wiring diagram:
Old Mar 29, 2006 | 05:08 AM
cangim's Avatar
cangim
I don't completely agree with the chart. But, none the less. I believe you have a generic trailer wiring kit, your Yellow/Brown and Green/brown are supposed to be tied together to brown. They are the marker light wires. It is setup to run two strips of wire down each side of the trailer to the tail lights. Since white is ground and you can ground each light to the chassis all you need is to run the two wires to each light.
Old Mar 29, 2006 | 05:41 AM
ncranchero's Avatar
ncranchero
Well the chart came from Grote, Cole-Hersee or Truck-lite, don't remember which. I just assumed they knew about lighting...........
Maybe these people know more.
http://g.msn.com/9SE/1?http://www.ac...=4&CS=AWP&SR=4
Old Mar 29, 2006 | 06:52 AM
subford's Avatar
subford
From the 1995 Ford Shop Manual
Old Mar 29, 2006 | 04:01 PM
cangim's Avatar
cangim
[QUOTE=ncranchero]Well the chart came from Grote, Cole-Hersee or Truck-lite, don't remember which. I just assumed they knew about lighting...........QUOTE]
The 4 way & 5 way are right, but once you go to 6 or seven, red is used for Left turn and stop, yellow then becomes the AUX or Backup, and Black is the 12V primary charge line. I wonder when the chart was made, at the time that may have been what everyone was going by.
Old Mar 29, 2006 | 05:18 PM
subford's Avatar
subford
In all the 18 wheel trailers I have wired (and there have been a lot) and other trailers I have never seen a yellow wire used for anything other than Left turn (and stop on small trailers).
The 18-Wheelers did use red for stop lamps.
Old Mar 29, 2006 | 08:09 PM
mountaineer man's Avatar
mountaineer man
But I always try.
first off the brown and yellow brown are connected together in the plug and are both for the tail lights look at the tail light on the trailer and you will see that the yellow and yellow brown go to one tail light and the green and brown goto the other light and the white wire goes to the frame of the trailer. the tail lights are grounded to the frame of the trailer.
I hope this helps you.
Mountaineer man
Old Mar 29, 2006 | 08:35 PM
tenptbuck7mmmag
Trailer Lights
Hey
Thanks Everyone, I think maybe I can hook up the trailer lights with ya'll help.
