Spring Has Sprung!!!!
Old Mar 27, 2006 | 09:35 AM
Fifty F3's Avatar
Fifty F3
Talking Spring Has Sprung!!!!
Some of you may remember me asking last fall if it were preferable to remove the flathead 8 from my 1950 F3 with or without removing the front sheet metal. I have since taken the advice given, and pulled the fenders et al and the engine and transmission. While the sheet metal still remains off, the flathead and crash box are now back in and today it started right up!!!
In the interim, I disassembled the engine, had the block cleaned and magnafluxed, and the crank machined. I replaced the main, rod and cam bearings, as well as the valves, guides and springs. New rings, too, of course. I've been through the transmission and made all new gaskets. Made a new wiring harness from scratch, too, and have made 81 of the 92 connections so far. The radiator has been cleaned and tested and the heater core replaced. A whoe lot of cleaning and painting was involved, too. Even fixed the horn.
Enough of this raving - the sun's out, it's 40 degrees on the way to 50 and I'm going trucking!!!! It's great being retired.
Old Mar 27, 2006 | 10:39 AM
Randy Jack's Avatar
Randy Jack
Hey, Dave!
Congratulations. You are well down the checklist on your build-up.
I took my own advice and stripped the front clip off my 56 to pull the motor next weekend. Sure looks wierd that way.
Old Mar 27, 2006 | 10:55 AM
fatfenders56's Avatar
fatfenders56
we need to see some pictures of all this!!!!
surfen24
New Member Introductions
Apr 7, 2014 03:47 PM
Prototypemech
Dec 24, 2013 10:05 PM
fifthytwo
Mar 22, 2010 10:45 AM
Dodge41
Nov 19, 2009 04:48 PM
abe
Apr 9, 2009 04:13 AM
