SRW or DRW
Old Mar 26, 2006 | 10:06 PM
Mudman's Avatar
Mudman
SRW or DRW
In the next year or so, I am thinking about replacing the frame on my truck. It has seen better days. At the same time I am going to reinforce the new frame. While I am changing the frame, I am debating about changing the truck into a dually. I can get an 86 cab and chasis frame, axles and springs. If I make it a dually I am not sure if I will put a box back on the truck or a flat bed. I want to run at least 35-37" tires. The truck is used to pull my trailer, plow snow, and off-road lightly. The truck is currently a 1984 F-350 4x4 60, 10.25, 460, 4spd, 4:10. Thanks for your opinions,
Mudman
Old Mar 30, 2006 | 08:45 AM
kawcrasher's Avatar
kawcrasher
I think a srw does much better in snow or mud-the duals dont have enough contact pressure with the ground. If you go with duals you will limited on tire choices as you can't run a very wide tire.
Mudman
13
Mar 23, 2007 11:52 PM
Mudman
Feb 6, 2006 09:16 AM
Mudman
Jan 31, 2006 11:57 PM
Mudman
Aug 12, 2003 09:27 PM
Mudman
Feb 25, 2001 09:39 AM
